2000 Stage 3 Audi S4 Nogaro Blue
Year: 2000
Make: Audi
Model: S4
Price: $11000
Mileage: 165
Color: Blue
Location (State): NE
Transmission: Manual
Drivetrain: 4WD & AWD
Engine/Drivetrain-
-OEM RS4 K04 Borg Warner Turbos 5/14
-APR Stage 3 tunes, 91, 93, and 100 octane 5/14
-RS4 Fuel Pump 5/14
-RS4 MAF 5/14
-RS4 Injectors 5/14
-RS4 MAF housing 5/14
-APR Bi-pipe
-Forged 007 diverter valves
-Vast Stage 3 Clutch 7/13
-3" SSAC Down pipes
-3" Borla dual exhaust with Bolt in Cut Out (open cut out sounds amazing!)
-New Bosch o2 sensors 8/14
-New water pump -7/13
-New timing belt -7/13
-New cam seals - 2/15
-New valve cover gaskets - 2/15
-New Wrinkle Red valve covers - 2/15
-New NGK BKR7E plugs gapped to .025
-ECS Magnetic Tranny and Oil drain plugs
-New USP Slave cylinder with Steel Braded line 5/15
-New updated oil cap
-New Car Quest battery 7/14
-New JHM turbo oil return lines 4/15
-ECS 2.0 Coil Conversion kit with ICM Delete
-New upper intake hose kit
-Fresh oil change 6/15
Suspension/Brakes ?
-Stoptech ST-40 332x32 Front slotted Big Brake Kit with steel braded lines 7/13
-New Stoptech rear slotted rotors with Brembo pads 2/15
-New KW ST Adjustable Coilovers 8/14
-New Meyle 12 piece Heavy Duty Full control arm kit 8/14
-New left and right axles 6/15
-Wheel alignment on 4/15
Exterior ?
-18x8.5 ET35 Peeler rep wheels. Square set
-225/40 Pirelli P-Zero All Season tires. 90% tread left
-Black mirror caps. (Also comes with the Nogaro Blue caps as well)
-Red taillight overlays
-LED plate lights
-Car has been detailed religiously during my ownership and has always been Hand Washed!
Interior -
-Podi boost gauge
-New Custom Flat Bottom Perforated Leather steering wheel with Blue Stitching
-New Custom S4 floor mats with Blue Piping. Front and Rear
-New Blue Alcantara shift boot
-New RS4 shift ****
-Stratmosphere short shifter
-New Custom Perforated Leather E-brake boot with Blue Stitching
-New Dark Carbon interior trim all around. (Hydro dipped)
-New AWE pedals with dead pedal cover
-New A6 rear view mirror with Compass
-New rear Bose woofers
-20% Ceramic Tint all around
-New Full LED interior light kit
-Dash cup holder actually works!!
-Zero tears on the Leather seats!!
BADS: Check engine light and Air Bag light is on, and dead pixels, all common issues with the B5. 3rd gear grinds a bit. Probably the synchro. Has dent on the hood.
The car does NOT smoke or leak any fluids. Also Zero rust on the car. This is a very clean well sorted build with very tasteful high quality Mods. Nothing ?repair? wise needs immediate attention on the car. I have driven it to both Georgia and Texas within the past 3 months with Zero issues. I wouldn?t hesitate to drive this anywhere in the country, its ready to go!! I?m also throwing in an extra set of Stoptech Ceramic pads for the front Big Brake Kit, Kayser non-forged diverter valves, NGK spark plugs, OEM Fuel filter, and few extras.
Clean title. Asking $11,000 as is. Please let me know if you have any questions, thanks!!!
More photos @ http://www.audizine.com/forum/showth...-3-Nogaro-Blue
2lflat4
Nov 18, 2019 05:05 PM
PelicanParts.com
Audi Vendor Classifieds
Aug 21, 2015 01:28 PM
