1986 Porsche 944 NA (Base) $5800 137,xxx
Year: 1986
Make: Porsche
Model: 944
Price: $5800
Mileage: 137500
Color: Guard's Red
Location (State): CO
Transmission: Manual
Drivetrain: Rear Wheel Drive
Records back to 1998
Significant Maintenance:
Belts and water pump changed every 30,000 miles since at least 2002
Transaxle filled with Swepco 201 since at least 2002. Currently filled with Swepco 201 changed ~1500 miles ago.
Alternator replaced 2007
Radiator and hoses replaced 2007
Coolant overflow tank, cap and hoses, 2007
Thermostat replaced 2007
DME replaced 2007
Clutch replaced with Sachs metal unit 2011
Odometer replaced, 2012
Koni Yellow Adjustable sport shocks installed 2012
Battery replaced 9/2013
Rod bearings and pan gasket reseal 2013
Refurbished steering rack installed 2015
Belts and water pump professionally replaced 1/2015
Rear hatch resealed 2015
New J-boot and breather hoses, 2015
AOS and dipstick gaskets replaced, 2015
OEM fuel filter installed, 2015
Major vacuum tubes replaced with silicone vacuum lines, 2015
Rear gas overflow and sunroof drainage tubes replaced, 2015
Intake manifold cleaned and painted in ceramic paint, 2015
OEM Driver's door seal, 2015
Full Bosch silicone plug wires, plugs, rotor and distributor cap, 2015
Upgrades:
Koni Yellow adjustable coilovers
Sachs clutch
Magnaflow Sport exhaust (cat-back)
K&N Air filter
Alpine stereo with Focus speakers front and rear. Fantastic audio, AUX and USB inputs, OEM fader slider works
Rear hatch seal and engine bay seals from Only944.com
Inner and outer shifter boots from Only944.com
Round throttle cam replacement
Wheelskins black leather steering wheel wrap
Larger, LED vanity light rearview mirror installed
LED instrument cluster light refurbishment
Stainless steel shift pin and thrust bearing install on shifter, eliminating play
Only944.com billet aluminum seat back release ***** and sliders
Weatherguard rubber footwell and cargo area liners
HD battery cables and corrosion-free firewall ground.
Genuine faux alcantara dashboard topper
F9Tech solid state DME relay installed. Improves start-up, reliabilty.
944MAX tuned DME EPROM installed. OEM DME chip included. Rock solid idle, more torque, excellent drivability.
Interior is Porsche cloth script seats in good condition. One cigarette burn in passenger seat bottom. Power driver's seat works well. Passenger seat manual.
All systems work well.
Strong brakes with no squealing.
Wipers front and rear work well.
Sunroof works perfectly and doesn’t leak.
No exterior leaks at all.
Glass is clear and unchipped all around.
Power window lifters and power mirrors work well.
AC blows very cold and heater gets very hot. Have run car hard in the summer at 105F with AC on high and no overheating.
Single stage paint has chips and a single split. One 1cm rust bubble forming on driver's door entrance (body side, not door). I meant to attend to that and didn't. ~5cm bubbled split in left rear quarter panel, under clear rock protector.
Car looks amazing from 10 feet. A great example for driving, not necessarily for show. I can't imagine being able to buy a better handling car of the Porsche marque at this price point.
Includes winter snow tires and Falken summer street tires.
I thought that I would be keeping this one, until I caught the Cayman S fever.
Located in Boulder, Colorado.
