2003.5 G35 Twin Turbo (625 whp)
Old Jul 3, 2016 | 06:05 PM
pd0019's Avatar
pd0019 is infamous around these parts
2003.5 G35 Twin Turbo (625 whp) (sold)
Year: 2003
Make: Infiniti
Model: G35
Price: $0
Mileage: 35000
Color: Pearl White
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
Year: 2003.5
Make: Infiniti
Model: G35
Price: $old
Mileage: 35,xxx
Color: Pearl White
Location (State): Pasadena, CA
Drivetrain: RWD
Reason for Selling: I have retired from racing
Sold
Summary:
A high performance coupe, formerly a daily driver that could be comfortably driven on the street as well as perform impressively at the race track, now exclusively a track day car. Featuring a Mark Brent-built engine and Jim Wolf modified Honeywell-Garrett twin turbos, this car gets 645 lb/ft rear wheel torque and 625 hp at rear wheels.
I am the original owner and this has always been a CA car. All modifications are in excellent condition, car has been well driven and never been in any accidents or paint swaps. The build was done by Jim Wolfe himself. Engine is new, less than 50 miles. (Flat-Trailer and additional equipment included with sale). This car has not been driven in a year and new fluids and tune required.
Car has been featured in Nissan Sport Magazine, C-16 Magazine, Sport Compact Car Magazine.
Details:
The Turbochargers & Control:
  • JWT Twin Sport 700BB Turbo System with modified water-cooled, full ball-bearing Honeywell Garrett turbos
  • JWT High Efficiency Intercooler
  • JWT FMU/Timing Controller
  • TechnoSquare L-Spec ECU program
  • Blitz four channel programmable boost controller
Engine:
  • JWT S2 cams & valve springs
  • JWT 1000cc fuel injectors
  • Arias 8.5 to 1 static compression pistons with ceramic coated crowns & skirts
  • Eagle connecting rods
  • Nismo rod bolts, main studs & head studs
  • Nismo main & rod bearings
  • New Nissan oil pump
  • Ported & polished heads
  • Ported & polished plenums
  • Block re-decked and bored & honed with torque plate
  • Crankshaft micro-polished & dynamically balanced
  • Rotating assembly (crank, rods & pistons) balanced
  • JWT aluminum oil pan spacer
  • Motordyne Engineering ½” Iso Thermal plenum spacer
Exhaust:
  • Dual stainless exhaust system with titanium tips
Cooling:
  • Koyo three row aluminum radiator, distilled water with Redline Water Wetter
  • Nismo 1.3 bar radiator cap
  • Setrab lube oil cooler
  • Amsoil 0W-30 synthetic racing oil
  • Amsoil engine oil pre-charger/pre-oiler
  • Amsoil BMK-13 Dual Remote Filter System with full flow & by-pass filtering s
  • Nismo power steering cooler
  • VIS vented carbon fiber hood, painted OEM Ivory Pearl
To Deliver TT Power to the Ground:
  • Rogue short shifter with Nismo GT ****
  • ATS (Active Traction Service) 9” Triple Disc Carbon Clutch & lightweight (10 lb.) flywheel
  • Nismo limited slip differential with Redline fluid & MOC differential lubricant
  • Enkei NT03+M 18x9.5”F/18x10.5”R track wheels with 275/35F & 315/30R Nitto NT-01 tires
Instruments & Gauges, Etc.:
  • AEM 52mm electronic Air/Fuel Gauge
  • AEM 60mm electronic Boost Gauge
  • AEM 60mm electronic Fuel Pressure Gauge
  • Greddy 60mm electronic Exhaust Gas Temp Gauge
  • AEM 60mm electronic Oil Pressure Gauge
  • Greddy 60mm electronic Water Temp Gauge
  • Automotive Entertainment custom molded gauge panels
  • G2X Datalogger hardwired in dash console
Safety & Handling Mods:
  • Sparco Milano seats with five point pull down racing harnesses
  • Sparco shoulder pads
  • Autovation drilled aluminum pedals
  • Custom six point tubular roll bar with quick release harness bar
  • AP Racing Brakes - Front 6-piston, 14.25” rotor & Rear 4-piston, 13.5" rotor with racing hat,
  • Braided stainless brake lines & Motul RBF 600 brake fluid
  • Stance coilover dampers with 12kg springs
  • Stillen front & rear adjustable sway bars
  • Nismo suspension & body bushings
  • Custom built Pro Series G35 front strut tower brace
  • Stillen G35 rear strut brace
  • Unitech Racing front camber adjustable upper control arms
  • Stillen rear camber adjustable links
  • APR adjustable rear wing
  • Kognition custom front splitter and undertray diffuser
  • Three nozzle cabin fire suppression with 10 lb. trunk bottle
I am sure I am missing many mods but the above can give you an idea of the detail, parts and work done to this car. My price is OBO. With very little work, you can have this car up and running. I will put you in contact with the people at JWT to whoever purchases this car if you choose to have them do the tuneup. They can vouch for this car as well.
Images:
Video of the car:
Old Jul 4, 2016 | 06:07 PM
hawg4fun's Avatar
hawg4fun is infamous around these parts
Your car
I am not a builder nor mechanic so this maybe a silly question
Is the car still street legal ?
Kevin in Denver
720 987 6864
Hawg4fun@yahoo.com
Old Jul 4, 2016 | 08:01 PM
zer0t's Avatar
zer0t has a spectacular aura aboutzer0t has a spectacular aura about
Bad ***.
Old Jul 5, 2016 | 07:42 AM
pd0019's Avatar
Kevin in Denver
720 987 6864
Hawg4fun@yahoo.com
The car will not pass CA smog but it may pass smog in other states, but you'd have to your own research as I'm not familiar with each state's regulations.
Originally Posted by zer0t
Bad ***.
Thank you
Old Jul 5, 2016 | 07:45 AM
hawg4fun's Avatar
Thanks and No worries on emissions as it would be registered in Montana
Old Jul 7, 2016 | 04:19 PM
Thadude's Avatar
Thadude is infamous around these parts
Please PM me with your contact info to discuss.
Old Jul 7, 2016 | 10:07 PM
pd0019's Avatar
Hi Thadude, can you please leave your email in your profile and I will contact you direct.
Old Jul 8, 2016 | 07:44 AM
pd0019's Avatar
Hi, please email me at pd0019@gmail.com and we can discuss any questions you may have.
Old Jul 9, 2016 | 03:59 PM
Thadude's Avatar
Thank you. Will do.
