2001 Porsche Boxster S - IMS replaced
Year: 2001
Make: Porsche
Model: Boxster
Price: $11000
Mileage: 100550
Color: Seal Grey
Location (State): SC
Transmission: Manual
Drivetrain: Rear Wheel Drive
Excellent condition mechanically and good condition aesthetically, this Boxster S (6spd manual) has been meticulously maintained. This is an excellent driver’s car – daily drive it and/or take it to the track/AutoX on the weekend. I’m moving on to a larger car for daily & track duties, so I’m letting the Boxster go to a good new home. Car is located in Charleston, SC. The title is clean and in-hand.
Upon purchasing (I’m the 3rd owner), I overhauled the car and addressed all potential failure items, most notably replacing the Intermediate Shaft Bearing with a new bearing. The old IMS was in perfect condition, which was a relief, but I gained peace of mind with the replacement. The RMS was replaced @ 68k miles by Jim Ellis Porsche prior to my ownership with the updated 997 part and does not leak. New clutch & flywheel were also done with that service @ 68k, and they showed no signs of wear. I replaced the IMS seal as well, so there are absolutely zero leaks from the rear of the engine. The car does not burn any oil or coolant. Other major and costly items that were recently addressed – I just replaced the brake rotors, brake pads, and tires (Hankook Ventus V12) at all 4 corners and had the car aligned. In addition to the standard maintenance items, the engine mount was upgraded to the 987 Porsche part, and I added a soft engine mount insert as well as upgrading the transmission mounts with semi-solid units from FUNCTION-FIRST Performance. The stock shifter was tired and throws were like a rowboat, so I added a short shift kit with Function-First Classic Delrin shift **** to resolve that. I also just replaced the soft top with a brand new black canvas and rear window. The interior is in very good condition, and all buttons/electronics in the cabin work.
Full Transparency…This is a driver’s car more so than a show car, so there are a couple things to note – Interior: the driver seat has bolster wear on the outside, the driver door pull has some scratches; Exterior: there is a scratch on the trunk lid, a scuff on the rear bumper above the license plate, and there is a tiny ding with paint chip on the rear qtr panel, the right front fender was repainted at some point so there is one area where the clear coat is fading, and 2 of the 4 wheels are showing some curb rash.
Here is an in-depth list of all the major maintenance & new/replaced Items with corresponding mileage:
ITEM & MILEAGE
Water Pump 63,725
AOS 68,177
Clutch 68,177
Flywheel 68,177
RMS (updated 997 part) 68,177
SAI Pump replaced 84,942
Windshield replaced 97,250
Air Filter (intake) 98,000
Cabin Filter (charcoal) 98,000
Engine Mount (updated 987 part) 98,000
Engine Mount Insert - SOFT (FFP) 98,000
IMS Bearing replaced 98,000
Oil Change (Motul Xcess 8100) 98,000
Oil Filter 98,000
Rear Tires replaced (Hankook V12) 98,000
Semi-Solid Trans Mounts (FFP) 98,000
Short Shift Kit 98,000
Classic Shift **** - Black Delrin (FFP) 98,000
Alignment 99,500
Brake Pads 99,500
Brake Rotors 99,500
Front Tires replaced (Hankook V12) 99,500
Full Nut & Bolt 99,500
New Soft Top & Rear Window 99,500
semicycler
Apr 2, 2016 09:31 AM
ECS Tuning - VW
Mar 22, 2016 02:14 PM
ECS Tuning - BMW
Mar 22, 2016 06:52 AM
