2007 Twin Turbo LS7 C6 1100whp
Old Feb 4, 2017 | 10:41 AM
cwylie's Avatar
cwylie is infamous around these parts
Year: 2007
Make: Chevrolet
Model: Corvette
Price: $55000
Mileage: 22000
Color: Black
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
Very sorted setup with the cooling to handle the HP and no issues being a street car. Stereo works, A/C works, mild driver until you put your foot in it.
2007 C6 Fully Built Twin Turbo with 22k miles, 1100whp on e85 and 800whp at 10lbs on 93. The drivetrain is fresh with less than 5k miles.
ENGINE
ERL LS7 block with recent refresh. Cylinders were cleaned up and has new wiseco 4.135 pistons and compression was set to 10.5:1, Callies ultra H-Beam Rods, dragonslayer crank, All bearings were replaced as well as a new kateck oil pump. WCCH ported ls7 heads and stock ls7 intake manifold, Pfadt engine mounts. Turbo kit was built by ips motorsports, Low mount twin Forced Performance gt3586r HTA billet wheels. Turbos were also serviced and inspected by forced performance ago during the refresh. Flex fuel sensor. Katech Valve covers and coil brackets. ATI damper. Katech Belt tensioner. Mezier WP419 Billet mechanical water pump, Dewitts radiator, D3 dual spal fans. Full dual 3 inch exhaust with center exit for Breathless performance diffuser. Mechman 220amp billet alternator.
FUEL SYSTEM
Fore Triple Walbro 450 fuel pump setup with controller, -10 feed line and -6 return all AN fittings, Aeromotive Regulator, ID1700 injectors
DRIVETRAIN
New Mantic triple clutch, Driveshaft Shop 3.5 inch aluminum driveshaft, RPM z06 level 6 Tr6060 and stage 3 z06 diff, Pfadt trans mounts, MGW shifter with billet shifter box, line lock, half shaft safety loops. New Z06 front brakes and base brakes to fit 15 inch rear wheels.
SUSPENSION
Pfadt coilovers, Delrin suspension bushings, LG drag spindles, Weld RTS 15” with 315 ET Streets, Weld RTS 18x8 fronts with Toyo 255 tires.
INTERIOR
Caravaggio race seats, Caravaggio center console lid, Caravaggio E-brake lever and boot, Defi boost and fuel pressure gauge, Ethanol gauge, Boost leash Boost controller with on board Viair air system, NGK AFX wideband, Fire extinguisher, Touch screen double din stereo, focal 3 ways and JL amp.
Exterior
MCM carbon fiber hood, C7 ZR1 front carbon splitter, Extended carbon rear spoiler, Carbon Zr1 Side skirts and Breathless performance rear diffuser.
2007 C6 Fully Built Twin Turbo with 22k miles, 1100whp on e85 and 800whp at 10lbs on 93, Tuned by James Karger. The drivetrain is fresh with less than 5k miles.
ENGINE
FUEL SYSTEM
DRIVETRAIN
SUSPENSION
INTERIOR
Exterior
The forgelines are no longer with the car but here are the pictures of it on the forgelines.
Asking $49k
File Type: jpg
Old Feb 4, 2017 | 03:06 PM
unvmy996's Avatar
Gdam that's a lot of car for the money! Glws
Old Feb 4, 2017 | 05:00 PM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
great bang for the buck!
Old Feb 5, 2017 | 05:25 AM
1BADBURB's Avatar
1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !
So is it a base c6 or a z06?
Any interior pics?
Any track times (mile, drag etc)
Any videos?
Clean history? Paint work?
I have a 1000hp built cts-v I'd consider trading for but need to know more details. Thx!
Old Feb 5, 2017 | 10:02 AM
cwylie's Avatar
So it started life as a base model but the only thing thats not z06 at this point is the steel chassis. All OEM body pannels. The paint is extremely clean. I never took it to the track but I have a dyno video from the previous owner I will find. I used it as a street toy for the most part and the wife and I would drive it out to dinner and what not. I would take it to work on occasion.
Old Feb 5, 2017 | 03:09 PM
LoneWolf's Avatar
LoneWolf is infamous around these parts
Pl
PM Sent.
Old Feb 6, 2017 | 10:46 AM
cwylie's Avatar
Added a lot more pictures
Old Feb 7, 2017 | 12:21 PM
cwylie's Avatar
Dyno Video:
Old Mar 2, 2017 | 10:22 AM
cwylie's Avatar
Still open for trades. Willing to add money as well for the right car.
Old Mar 3, 2017 | 12:10 PM
The_Ruski_Driver's Avatar
The_Ruski_Driver is infamous around these parts
Brave guy to spend that kind of money on an 07 base. Looks and sounds like a monster!
Old Mar 6, 2017 | 10:18 AM
cwylie's Avatar
Thanks. I mean at this level of HP/build I dont think it really matters what it started as. Unless you have to go to the bank to get a loan.
Old Mar 30, 2017 | 10:49 AM
cwylie's Avatar
Car is on the welds full time now. Just got a brand fore triple pump fuel system and ID1700 injectors. Brand new 18x8 Weld RTS Fronts. New asking price without the forgelines is $49k.
Old Apr 7, 2017 | 02:43 PM
cwylie's Avatar
Bump
