Can anyone critique a CR Spotless system
I'm ready to order one (CR Spotless DIC-20)and although the general consensus is it performs as toted although there are some negative comments as well...does it live up to it's claims or will it soon become an " in the box in the corner forever" item..tia
https://images.costco-static.com/Ima...recipeName=680
Good to hear...just ordered from Costco..I plan to plumb with a gate valve for easy bypass..and rinse though my pressure washer with reduced pressure (I have pressure adjustment on the wand) ...nice wheels there
Now I do it all through the pressure washer. I use the "two bucket method" presented on YouTube.
I was just trying to see how hard it will be to get hot water in the garage. Should have thought about that when we built the house but we were coming out of a small apartment.
What's so tough Stealth ? do the canisters not simply screw off ?..(not having them here yet)...I did read on one post the resin holder can separate and resin flow out...
Your kit should have came with this tool which makes it easy to torque the canister off.
The system is amazing. Rather than dusting off cars, I just rinse and walk away. Does take a few hours to completely dry and you want to avoid dust blowing onto in mean time.
MAYBE THE ISSUE IS THAT THE CANISTER IS PLASTIC AND I LEAVE IT OUTSIDE SO IT MELTED CLOSED.
