OEM 4" door speaker part number?
Yep... when I replaced my speakers, I dumped the whole set of Bose on ebay dirt cheap
I hope you're not "downgrading" from something else back to the OE drivers. Is it that the PO actually removed and did not replace them with anything (must be a story there, if so)?
previous owner had something aftermarket in there, and must have pulled them before trading the car in. There's a random 8 ohm TWO INCH speaker in the 4 inch spot. I'm replacing the 8" woofer with a Focal driver. I'm gonna have a pro check the whole system to make sure everything is cleaned up. Before seeing the car, he recommended I get some OEM speakers, in case the Focal's impedence doesn't match.
Whats the resistance of the oem door bose 4" speakers?
Check out this ginormous thread which is likely to have info you need -
https://www.6speedonline.com/forums/...3-22-15-a.html
yeah I saw that thread, that's where I got the idea for the 8" IS200 speakers. Just didn't realize I also needed midrange drivers, when it came time to install them
gonna try these, before OEM. Woofersetc confirmed that they're designed for plug and play with OEM amps
http://www.woofersetc.com/focal-isn-...onent-set.html
