996 ctr
Old 08-28-2017, 03:00 PM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
996 ctr
CTR = Carrera Turbo R
Actually I'm not really sure which would be the correct forum for this creation of mine, but while it shares a great deal of parts from 996 GT2/3/turbo/Cup this could be a proper place to be.
One upon a time it was an aerokitted 996, MY '00. Then it got some stuff, in and out and now it is what it is.
Specs in next posting, now just some pics.
C: Arska
F: 265/35-18 & 10x18 et 37 R: 295/30-18 & 11x18 et5
MPSC2 & NTM Racing wheels
C: Tero Niemistö
Old 08-28-2017, 03:01 PM
pete95zhn's Avatar
Specs:
Body
-2000 2wd
-89l tank conversion, including appropriate bulkhead
-CF front bumper*, front hood*, roof*, front fender vents** and rear fender extensions***
-front fender extensions are 993GT2's, GRP over OEM steel fenders (to maintain OEM Litronics)
-Joe Toth's canards
-db motorsport splitter
-Lexan side and rear windows
-996 GT3 rear hatch and wing (aftermarket) and Demon Speed Motorsports wing uprigts, the tall ones
-RUF Rturbo inspired IC inlets in steel
-RUF Rturbo (copy) rear bumper modified to fit fender extensions
-997 GT3 flat bottom panels with appropriate rear brake cooling ducts
-front fender liners customized to vent radiators into wheel wells and out from fender vents
Complete respray in OEM Arktissilber Metallic, L92U
*ACC-Porsche-Teile
**Zimspeed, 997 GT3RSR, modified
***Zimspeed, 996 GT3RSR
Suspension and brakes
-Bilstein Cup 3-way adjustable coilovers w remote canisters, valved for 120 / 160 N/mm Eibach springs
-996 GT3 adjustable sway bars
-GT3 2-piece LCAs F&R, F inner parts are from 997 GT2RS (15mm wider)
-9products adjustable toe links and locking plates, w bump steer correction
-Rennline adjustable front diagonal arms
-9products upper rear control arms
-9products sway bar drop links
-997 GT3 front camber plates with 9products "transfer plates" (top mounts are 25mm outboard from OEM)
-front and rear subframes are machined to '02 GT3RS specs (=lower)
-all bushings are monoballed
-997 turbo front and 997 GT3 rear calipers
-Brembo 2-piece 350mm front discs, 997 turbo 350 rear discs
-PFC 08 pads, will most likely change back to Ferodo DS1.11...
-996 GT3 MC and brake booster, electric vacuum pump in front compartment
-PSM switchable fully off
Wheels: NTM Racing (Italy) 3-piece, 10x18 et 37 & 11x18 et 5
Tyres: MPSC2, 265/35-18 & 295/30-18
Front and rear widths, measured from wheel's outer edge at hub's height are 1840 & 1880 mm.
Interior
-full GT3 interior, rear seat delete-radio delete-AC-9products steering wheel extension-Rennline pedals-alcantara this and that instead of OEM leather imitation
-GT3 front console delete, center console painted in body colour
-instument and HVAC panels from 996 turbo (to work with ME7.8)
-Cobra Suzuka Pro seats in leather and alcantara
-6-pt harnesses
-Heigo 6-pt rollcage with FIA padding
-fire extinguisher in fron pax footwell as in GT3s
-Race Technology DL-1 datalogger with Dash 3 display permanently installed
Engine
-996 turbo, redline at 7200 rpm
-9products LW underdrive pulley
-all air routing in and out from the engine are from 997, including 997.1 VTG turbos
-997 GT2 ICs
-do88's turbo inlet hoses
-IPD Y-pipe and plenum
-one Hitachi MAF in LF turbo inled channel, signal doubled in programming
-SAI delete
-Bosch EV14 injectors, 613 cc
-5,0 bar FPR
-Walbro GST450 pump
-AN8 fuel line
-custom 3" exhaust, 100 cell cats and Burns Stainless mufflers, X-type center exit
-ME7.8, tuned by erikoismoottori.fi
-external electronic controller for turbos, tuned by myself
Transmission
-basically 996 turbo transmission, but
-front and center casings are from 996 GT3 Cup, as well as oil cooling system
-997 GT2 mainshaft and 1&2 gears
-Guard's straight cut 3rd
-steel synchros
-CMS shift arrester
-997 GT3 Cup LSD
-Sachs Motorsport PP and unspringed clutch disc
-GT2 (actually Carrera) MC and slave
-LWFW
-996 GT3 Cup shifter and cables
-semisolid engine (Wevo) and transmission (DIY) mounts
Speeds in mph in different gears:
RPM -1st -2nd -3rd -4th -5th -6th
1000 -6.9 -11.4 -15.9 -19.3 -23.5 -29.6
7200 -49.4 -82.4 -114.2 -139.0 -169.3 -213.3
RPM Drops
Based on 6200 RPM
1st to 2nd = 2480
2nd to 3rd = 1726
3rd to 4th = 1109
4th to 5th = 1107
5th to 6th = 1280
Gear Speed at bottom of gear* / Speed at top of gear* / Speed range of gear* / % of Pull
1st - / 42.6 / - / -
2nd 42.6 / 71.0 / 28.4 / 20.1%
3rd 71.0 / 98.3 / 27.3 / 19.3%
4th 98.3 / 119.7 / 21.4 / 15.2%
5th 119.7 / 145.8 / 26.1 / 18.5%
6th 145.8 / 183.7 / 37.9 / 26.9%
https://weddleindustries.com/gear-calculator
Old 08-28-2017, 03:54 PM
SamboTT@ByDesign's Avatar
WOW Pete top notch! Can't wait to read and see more!
Old 08-28-2017, 04:38 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Awesome track weapon. It looks like something RUF would build.
Old 08-28-2017, 06:17 PM
Keo's Avatar
Keo
Keo is offline
Keo is on a distinguished road
Holy crap! Amazing
Old 08-28-2017, 07:07 PM
pwdrhound's Avatar
Very cool Pete! Car turned out fantastic, very RUFy. Looks like you and I are running identical front wheel size and offset. I'm assuming you didn't go with larger rears due to tire availability? With flares you could easily have gone 12-13 I would imagine. I think RUF runs 12s on the flared narrow body cars like the RGT.
Old 08-29-2017, 07:31 AM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Great looking car Pete, turned out amazing. I am really interested into knowing more how the car seats on only 295s in the back, is it balanced enough? The only Rcompound tire was able to find here is the crappy R888 315-335, considering keeping R18s only for slicks and going 19s for semis, but first have to stress a bit the R888s I have and see how they grip after few HC
Old 08-29-2017, 10:22 AM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
****. Nsfw.
Old 08-29-2017, 02:11 PM
VAGscum's Avatar
C: Arska
C: Tero NiemistĂś
Looks great, Pete!!
Any info on the PSM on/off functionality.
Old 08-29-2017, 02:17 PM
pete95zhn's Avatar
Thanks, specs added above!
I've always been a uuuge (...sorry, I couldn't resist...) fan of RUF. This car started as a Rturbo inspired narrowbody build. First IC inlets I did myself, but now when it was at painter's he suggested ones in steel. I supplied him the pics.
You guessed right about rear wheels, I have inner barrels which would make them 12,5" wide, but there's no decent rubber available in widths required. I guess 295 MPSC2 has grip equivalent of 335 R888/Kumho.
Considering front track, it's much wider than OEM. LCAs are 40mm wider (15mm from 997's inner ends and 25mm shims) and camber plates are moved about 25mm outboard with some tricks. I have 3,4 deg camber and with adjustable thrust arms caster is sensible too.
IMO its is, I'm beginning to find out right settings and on dry track it turns in like a charm. With sensible use of throttle I have no problem with corner exit oversteer either. In fast corners it feels quite well planted too, but there I'm just finding out the limits.
2:53 at Spa with these hands and feet, so it's not really bad, I guess. Summer here has been lousy, wet and cold, so no big (just some) improvement at local tracks so far.
Originally Posted by Keo
Holy crap! Amazing
Thx!
Old 08-29-2017, 02:29 PM
pete95zhn's Avatar
Originally Posted by VAGscum
Looks great, Pete!!
Just to confirm, I now use 6GT3's MC and brake booster. It was impossible to get 7GT3's MC working. BTW, the booster has 3.15 factor, while turbo's/Carrera's has 3.8, so pedal is a bit stiffer this way.
Last Saturday I switched it off from OEM switch in Time Trial while it all three races were either pouring wet, just wet or very damp, but it didn't really intervene. Not even in trailbraking. On Sunday's trackday it was dry but cold, switched it completely off ( have a switch under the dashboard). This way it leaves the PSM light on and suggests a vist to the workshop, but ABS is still working. I managed to massage 0,8 sec off from last year's best lap time, but there's still about a second to improve, looking from datalogs. All warnings disappear after next engine start if the switch is turned on again before starting.
Old 08-29-2017, 02:37 PM
VAGscum's Avatar
Had you looked into coding out the PSM and deactivating?
Old 08-29-2017, 02:48 PM
pete95zhn's Avatar
AFAIK coding the ABS/PSM unit is impossible. Additional switch practically deactivates it. Changing to GT3/2 or Motorsport unit would be the next step, but so far I do not feel it necessary, driving trackdays and occasional Time Trials.
Old 08-29-2017, 03:18 PM
pwdrhound's Avatar
PSM is not coded in the ECU but instead it's part of the dash logic and I'm not aware of anyone that has been able to jail break it. We have a local whiz that does all of our dash coding / programming and even he hasn't been able to crack it. To remove PSM permanently without any nuisance warnings you will need a GT2 instrument cluster for starters but that opens up another can of worms. To do it right is possible not not for the faint of heart.
Old 08-29-2017, 03:30 PM
VAGscum's Avatar
PSM is not coded in the ECU but instead it's part of the dash logic and I'm not aware of anyone that has been able to jail break it. To remove PSM permanently without any nuisance warnings you will need a GT2 instrument cluster for starters but that opens up another can of worms. To do it right is possible not not for the faint of heart.
Most Motronic managed engines with drive by wire have programmable clusters. But you are right, it has to be cracked. Most likely anyone with the ability to correct a cluster's mileage to match you car for a cluster change has the tools to change other parameters. And can for instance be programmed over to a GT2 for instance. Just have to find the guru.
