1991 BMW E34 M5, Alpine White $16,500
Old Nov 6, 2017 | 12:34 PM
Jblaw's Avatar
Jblaw is infamous around these parts
Year: 1991
Make: BMW
Model: M5
Price: $16500
Mileage: 175500
Color: White
Location (State): NY
Transmission: Manual
Drivetrain: Rear Wheel Drive
1991 M5, 175k miles. $23,000 in receipts for last ten years. Catless exhaust. Texas car with zero rust. Just received $500 detail. Recent steering box rebuild, timing chain tensioner update, oil pan gasket reseal, brand new Pirelli Super Sport tires. Extremely strong and a hoot to drive -- I would drive this car across the country without thinking about it. Also has updated 1995 gathered leather door panels.
Service history:
Date Item / Service Cost
2006 New clutch
11-2009 to 7-2010 Stoptech cross drilled rotors, brake pads and sensors, 3" straight exhaust, no cats, with magnaflox back box; Pioneer CD player; BC racing coilover suspension added; Dinan chip.
7-2010-12-30-2010 Rear pitman arms; radiator; sway bar links; oil cooler; thermostat; belts; waterpump; coolant hoses; ebrake springs + shoes; wheels; Dinan chip; M Tech 1 Steering wheel; replace vacuum hoses; spark plugs; strut mounts; air filter; front main seal; powdercoated valve colver, intake plenum, oil filter housing.
8/7/2010 Fuel injector service 132
1/4/2011 Sunroof Motor Cover 36.07
1/5/2011 Hood Strut 27.45
1/6/2011 Wiper blades 55.61
1/7/2011 Center Cap for Wheels 51.8
1/7/2011 Trunk Lid Struts 67.72
1/11/2011 Front door seals (x2) 118.21
1/19/2011 Valve cover gasket, spark plug hole gasket, tappet depressor 181.60
1/31/2011 Valve shims 29.94
3/2/2011 Sway bar bushings 27.95
3/3/2011 Tire patch, mount 51.34
3/9/2011 Repair output shaft leak from detent plate and output (transmission mounts, shalft seal, detent lock cover, exhaust downpipe gasket); Replace entire suspension (strut assemblies, strut housings, strut bellows, strut insets, pad clips, H&R spring set, rear shock, rear upper shock, bumper stops, spring pads, four wheel alignment); Replace idler arm; Replace left and support / control arm bushings; Top up R12 for AC; Replace Foglight; Replace fuse for windshield wipers; Replace U-Joint and steering shaft assembly and new bushing 5,148.20
4/20/2011 AC freon recharge, new schrader valve 109.44
8/9/2011 New AC Compressor, valves, freon, service 1,348.14
8/17/2011 A Pillar cover 60.07
2/15/2013 Replace upper shock mount 0
9/3/2013 Bosch spark plugs, antiseize compound for install 45.6
10/22/2013 Tire balance 60.98
10/22/2013 Replace left tire rod assembly, front end alignment 196.2
11/4/2013 New clutch slave cylinder; Change oil / filter; Reaplce pinion seal; replace valve cover gaskets -- check valve clearances, no adjust needed; Replace all three drive belts; balance four tires 2,020.92
5/20/2014 Prepurchase inspection: Pass front outer tire rod boot is torn, but tie rod has no visible play or wear; oil pan, valve cover and upper timing cover have slight leak, steering box has slight play, but other suspension components and bushings are within spec. The brake rotors and pads have plenty of life left. Exterior is excellent for its age. AC and heat work as they should. 110
8/5/2014 Ultimate Car Cover 199.95
11/25/2015 Wheel balance; Front arm support bushings replace; Replace center tie rod; Replace right tie rod; Replace idler arm; New AC control unit; Evacuate and add R134A freon; New battery $5,455.62
4/14/2017 Misc. hose clamps, upper spark plug wire cover and screws, new front and rear roundels, accelerator gromets, cruise control bracket 155.49
4/14/2017 Misc. coolant hoses, //M badge, throttle and cruise control cables 166.8
4/14/2017 NOS Light Up Shift **** 165
4/14/2017 Replacement door handle gaskets 17.8
4/16/2017 18" M Parallel Wheels 500
4/17/2017 New Michellin PSS 844.72
4/25/2017 Wheel and tire mount, general inspection, tighten belts 300
4/26/2017 UUC Short Shift Kit from Turner Motorsports 219.95
5/3/2017 Fan clutch, distributor cap and rotor (parts) 303.24
5/20/2017 Fan clutch, distributor cap and rotor (self installed) 0
5/20/2017 New Door Cards 350
5/21/2017 Re-Manufactured M Tech 2 Steering Wheel 460
5/13/2017 ///MBadge Installed (self) 0
5/26/2017 Parts: oil pan gasket, interior door handle caps, air filter, timing chain tensioner, front grill emblem, foglight bulbs, trim paint 209
5/29/2017 Rear ash tray 9.99
7/12/2017 Rebuild Steering Box 514.06
8/3/2017 Change oil, R&R steering box, install updated timing chain tensioner, install short shift kit 3082.97
8/29/2017 Oil sensor replace 168
Ten year total for repairs: $23,001.83
Please contact me at: jbeinhor (AT) hotmail (DOT) com
Old Nov 12, 2017 | 06:27 PM
Small Shrimp's Avatar
Small Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to all
VERY NICE. I had a 95 Euro Import. Loved that car. Sold it to a guy and 3 days later he got rear ended and totalled it . GLWS!
Old Nov 12, 2017 | 07:50 PM
Jblaw's Avatar
Thanks! Took it out this weekend for a great ride! What an amazing beast.
