P1507 Throttle code again
Old 02-21-2018, 05:52 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Unhappy P1507 Throttle code again
Throttle was cleaned up couple months ago, it did happened like an yr ago too, I purchased a second hand from Ebay and it gone wrong after 12 mths, put back the cleaned old one, ran fine for 2 mths and again.
But this time doesnt have bunch of codes, just P0102 and P1507, therefore P1507 is not clear-able via Durametric, even I reset the throttle and can have the code clear for a minute, it would come back again immediately when the next key on.
Sounds like this time I should have a new TB right? Thanks guys.
Old 02-21-2018, 09:51 PM
'02996ttx50's Avatar
i have exhausted every effort to suggest you simply replace the maf. if it doesn't fix it? i'll be shocked. GL brother.
P0102 = Mass air flow sensor
Old 02-21-2018, 10:05 PM
boyg's Avatar
Thanks mate, will do tonight, but as your code was P0507 and mine is P1507, similar but still different.
Old 02-22-2018, 09:20 PM
just sayin. its so long ago now. i dont even remember what codes i had! but still maf related. I'm gonna wager that a maf will cure your issue. if i am wrong? good luck collecting GL tho, really.
Old 02-22-2018, 09:29 PM
boyg's Avatar
Yea, thanks, I wish the maf could clue mine too, but I did have a try last night, the code stay there and not even able to wipe out by Durametric.
Old 02-24-2018, 10:50 PM
sorry, then yeah. you've gone round the roundabout. right back to a possible bad TB.
i hate to "throw parts"? but if i had to, and you've replaced the maf? sounds like a tb.
Old 02-25-2018, 03:54 AM
boyg's Avatar
So I drove it for couple weeks and nothing happened until this afternoon, rough idle I can make it start in few try, at least I can drive it home and these codes come out.
Old 02-25-2018, 09:57 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
1120 and 1121 def points to faulty throttle body. I had the same two codes. Ordered a new throttle body. See thread a few down on cheaper throttle body options.
Old 02-25-2018, 10:04 AM
boyg's Avatar
So for your case, after the new TB installed, anymore symptoms or codes comes back again?
Old 02-25-2018, 11:34 AM
Atrox's Avatar
Have not installed it yet it’s being shipped. However every time I do an e gas reset it clears those codes temporarily.
Old 02-25-2018, 12:46 PM
Iirc? The electrical component of the tb when intermittently failing can cause the butterfly not to fully close. I'm not that well versed in the OBD codes, but that is another issue I once faced that came to mind.
There was a gt2 tb available then and there for the swa,p so no other diagnoses was necessary.
Yeah at this point..I would swap in a new one. GL.
Old 02-25-2018, 03:51 PM
boyg's Avatar
Me2 besides the p1507, and drivable for a certain period, but you never know when.it would happen again...
Old 02-25-2018, 03:53 PM
boyg's Avatar
Seems like TB is the first to swap again, did you find a lowest brand new like usd 300 somewhere else?
Old 02-26-2018, 02:14 PM
I honestly cannot recall! Sorry..
again the last time I sourced a tb my issues were maf related and I gambled and won. As the codes indicated TB!
The last tb swap I did was on my previous 996 turbo and that time we had another tb available right then and there as I said earlier..
I am pretty sure the tb is 996/986 so double check and look for the 986 part if so! Just like the maf is cross compatible 996-986 boxter
Again gl
Old 02-26-2018, 08:08 PM
boyg's Avatar
I finally ordered it from UK, with 5 years warranty, wish me luck can have it resolve by replacing the tb.
Quick Reply: P1507 Throttle code again
