Help 07 DB9
Help 07 DB9
I went to visit my sister and a thunder storm came through and now car will not start.
There is a whirring sound coming from the box next to the passenger side firewall and car will not go into start up diagnostic when I turn the key on and doors and trunk will not lock or unlock.
Battery went dead and I charged it up, but I cannot get the ecm to reset, anybody have an idea of what to do?
Display says to check battery disconnect, but I cannot open the trunk and also says gears are not working and has a DCS error.
I did disconnect the battery when I was charging and no help.
Honestly no clue, but maybe a battery change out????? Then see if trunk will open, then hit the button in the trunk, and then the reset button under the back seat above the battery, maybe even a few times. That might do the trick
Mine went haywire when I was re-installing my Denison. I didnt have the tender on it, and had doors open and radio on off many times. Although things would come on with the key, radio didnt work, ac didnt work, lights all over dash etc.....Wouldnt give me red start light either. Battery was just so low power wise, the car shut all things down. So after a bit of charge, cranked up and still a few things were wonky. Charged by tender for 2 days, and then all seems fine now.
Just my experience. ITs always almost the battery when issues arise it seems.
I pulled into the garage, shut off the engine, realized the top was still down, so I switched on the key, raised the top, gathered up my stuff, and left the key in the ignition with it in switched on. Dumb right? So the next morning, I realized I didn't have the keys in my pocket, went out to the car, found the keys and a near flat battery. I also didn't bother to put the battery tender on the car that evening.
The trunk was locked, so I couldn't get in it. There is no manual way to over ride the switch that I know of, so I couldn't hook up the battery tender, not that it would have helped much at that point.
So I had a battery pack that I had bought at Costco that could be used to jump start a car. So I opened up the hood. Center Front of the engine is a Cover with a large red + sign on it. I hooked the red jumper to the terminal and the black to a solid ground. Tried cranking the engine but the battery pack was partially discharged, but I was able to unlock the trunk(boot) so I hooked up my battery tender. I then took my battery pack back into the house to fully charge it.
Two hours later, once the battery pack was fully charged, I was able to get the car started. I then had to reset the windows and the clock.
So even if you can't get the trunk open you can connect another battery or a set of jumper cables to the car to unlock the trunk and check your disconnect switch.
Mark
I am getting PATS failure message, Key in Ignition message and key is in my hand. I did try to jump the car first.
@sheriff Dep - my DB9 does not have the reset button and I charged my battery to 100% with a charger hooked straight to my battery and cables disconnected. I will try trickle charging for a while and see if that helps.
Is the key chime on with key out? Check the flap inside the ignition switch isn't sticking. Make sure key is out when battery disconnect/reconnect is done. Close hood and doors and try manually locking both doors with key. Verify battery in remote Fob is 3v. 2007 MY battery reconnect is electronically done via key cycle (ignition switched on)
Tried locking and unlock doors, they will lock manually but not unlock.
Ok, disconnected battery to check wiring and reconnected it and now key chime is on constantly and key flap is up. Also, display says key is in the ignition.
doors and trunk still won't open.
