removing dealer stickers
anyone have any tips on removing those annoying dealer stickers?
Place I got my 4S from wasn't happy with just putting on their license plate frame, they had to put a sticker on the body next to it......
Hi, Use a hair dryer or heat gun carefully to soften then I use a plastic 'razor' blade to lift off or a plastic body tool. Works quick and easy. Since it was likely just put on it should come off easy. I use a 8.99 Harbor Freight heat gun.
In the past I used goo gone to soak the backings with liquid, then gently lift using plastic trim flat tools.
Stubborn decals go away with gentle use of heat gun (dont keep it on one place long, keep moving side to side to heat up).
use a hair dryer if no heat gun. Have a little polish on hand too. A last clean up with that in case you make some light marks.
Other things that are fine and remove glue, nail polish remover, WD40. FYI. Neither will hurt paint. Wax.
werksracer
Merchandise For Sale / Wanted
10-25-2007 07:59 PM
KJM3
07-25-2004 01:25 AM
