For Sale: GMG 991 Turbo(S) Exhaust
Old 10-01-2018, 09:59 PM
Oerding911's Avatar
Oerding911 is on a distinguished road
Category: Engine - Exhaust
Price: $2500
Location (State): CA
USED 10,000 MILES
GMG 991.1 Turbo(S) Exhaust -- Equipped with High Flow Cats and Black Ceramic Coated Quad Tips
Retails for $5510 after tax. $2,500 Cash, PayPal, or Venmo is fine.
Local pickup in Gardena CA or Laguna CA. Shipping Available upon request (professionally packed)
Literature from their site;
"Handcrafted out of T304 Stainless steel and meticulously TIG welded to aerospace specifications with great precision, the system is lighter than the factory. Weighing in at 37 pounds, the GMG Porsche 991 Turbo exhaust system is 20 percent lighter than the factory system. The system features high flow German made HJS HD 200 cell sport catalysts and a crossover x-pipe to increase power by balancing the exhaust gas pulse coming from the engine and adds to the signature sound that only the GMG WC system can offer. The crossover x-pipe works by balancing the exhaust pulses from either side — or cylinder bank – of the engine. It allows the exhaust gases to flow down the path of least resistance while speeding up exhaust velocity. At lower revs, turbulence is formed as exhaust gases try to shuffle past a second column of gases coming from the other side. The X-Pipe merges the exhaust into two uniform streams, allowing a smooth flow from engine to exhaust exit.
High quality stainless steel packing is used in the mufflers to withstand extreme exhaust temperatures and high intensity acoustic pressures that are generated by the forced induction system that is located within very close proximity due to its rear engine configuration. This is one of the key advantages of the GMG exhaust system since most other exhaust systems uses fiberglass packing instead to lower costs, and they are prone to rapid deterioration.
Using the factory bracket location, the exhaust system is a direct bolt on replacement for the factory system. To ensure no CEL (Check Engine Light) and proper operation of the vehicle, the HJS HD catalytic converters are OBD2 compliant and the O2 sensor bungs are placed at their proper locations.
There are three tip options. You can opt to reuse your factory tips for a stealth approach, or you can run our signature Quad-tips in either a brushed stainless finish or a heat-controlling black ceramic coating.
Features:
  • Horsepower and torque increased up to 35hp without software upgrade
  • Gains up to 90 hp with software upgrade on 91 octane over 100 hp with 100 octane fuel (pending development)
  • Deep aggressive exhaust notes at lowers revs & exotic high pitched exhaust notes at higher revs
  • German made HJS high-flow, 200 cell sport catalysts; OBD2 compliant, no CEL (Check Engine Light)
  • Crossover X-Pipe to balance exhaust pulse
  • Stainless steel packing used in mufflers
  • No unwanted cabin drone
  • Constructed out of US Made T304 Stainless steel
  • Significant weight savings over the stock system.
  • Direct bolt on replacement, All hardware and clamps included
  • Requires no modification to vehicle
  • Made right here in Southern California
Vehicle Fitment:
  • 2013-2016 Porsche 991.1 911 Turbo / Turbo S
  • 2017-current Porsche 991.2 911 Turbo / Turbo S
Old 11-06-2018, 01:05 PM
Oerding911's Avatar
motivated seller ... make me an offer!
Old 11-20-2018, 12:15 PM
Oerding911's Avatar
price drop bump, 3k
Old 12-10-2018, 10:34 PM
Oerding911's Avatar
Christmas Sale Bump: 2.5k takes it
Old 01-01-2019, 08:52 AM
Tguerrette's Avatar
Tguerrette is an unknown quantity at this point
Still Available?
PM sent
Old 01-13-2019, 10:24 AM
roe's Avatar
roe
roe is offline
roe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud ofroe has much to be proud of
Still available?
Old 01-13-2019, 10:57 AM
Oerding911's Avatar
Originally Posted by roe
Still available?
yep!
Old 01-19-2019, 04:51 PM
BillR's Avatar
BillR is an unknown quantity at this point
Still have exhaust?
Old 01-19-2019, 05:55 PM
Oerding911's Avatar
Originally Posted by BillR
Still have exhaust?
yes, still available
Old 01-19-2019, 06:51 PM
BillR's Avatar
Why selling?
Old 01-19-2019, 09:03 PM
BillR's Avatar
What year Turbo S is/was it installed on?
Old 01-19-2019, 10:38 PM
Oerding911's Avatar
Why selling?
dont have the car anymore, if I bought another one I’d for sure put this system on though. No hassle, no drone, no CEL , exotic sound
Old 01-19-2019, 10:39 PM
Oerding911's Avatar
Originally Posted by billr
what year turbo s is/was it installed on?
2015
Old 06-04-2019, 07:17 PM
ArtF10M5's Avatar
ArtF10M5 is on a distinguished road
Is this still available?
Old 06-04-2019, 07:20 PM
Oerding911's Avatar
Yes, still available
