2005 continental air suspension
Ater hoisting-had it up 12 hours,when lowered, front end went flat on the floor.( both front air suspensions). Replaced front and rear shocks recently(60000miles) Reprogrammed and suspension ok,but getting intermittent hissing sound from r front area of car. Is this a sign of the compressor failing or what? Any ideas would be helpful.
Is the car dropping at any point especially over night? If not, its not your suspension.
If it does do a few checks before you spend any money on a shock.
Using soapy water check the area when the air line connects to the shock. Sometimes you get very lucky and its just this rubber seal thats gone. I had that a year ago. Also check which side is dropping first. I've found when my front right unit fails it will actually drop on both sides.
DressUpBoutique
Tuning/Modifications
04-27-2009 12:46 PM
