Trailer Hitch wiring
Old 10-22-2018, 10:54 AM
wtsnt's Avatar
wtsnt is an unknown quantity at this point
This is probably a really dumb question, but I have recently purchased a 2008 Cayenne S. It has the factory trailer hitch installed. However, I cannot seem to locate any wiring for the trailer. Is this located somewhere not readily visible, or was the trailer wiring a separate option not included with the factory hitch?
Thanks,
Terry Watson
Old 10-23-2018, 12:47 PM
asp13's Avatar
asp13 is an unknown quantity at this point
The wiring should be there, tucked away in the trunk storage on the right. You may need to do to a dealership to get it plugged in properly.
Old 10-26-2018, 12:17 PM
AJ88CAB's Avatar
AJ88CAB is an unknown quantity at this point
Is there a plug holder with blank plate next to the hitch? It would be tucked up under the bumper. If so, you have to remove the plate and install a plug adapter.
See this thread for required parts. This was for my 2006, but I believe it should apply to a 2008.
https://rennlist.com/forums/cayenne-...questions.html
If there is no connector blank plate & plug holder, I am not sure what your options are, I believe the factory tow package was complete except for the plug adapter (& a brake controller).
If this is not the case, I got nothing
Proceed as asp13 suggested.
Old 10-26-2018, 12:36 PM
wtsnt's Avatar
You hit the nail on the head. There is a "box" mounted up under the rear bumper next to the hitch with a cover plate on it. I figured it had to be the trailer connection, but have to admit I expected Porsche to provide a plug and wiring although probably without the trailer end. Thanks for the link to the Rennlist thread!
Terry Watson
Mz3bo
Cayenne 955/957
35
04-20-2021 06:49 AM
syavik
Cayenne 958
19
11-10-2017 10:03 AM
e60528i
Cayenne 955/957
01-24-2012 07:24 PM
markitzero
Cayenne 955/957
08-23-2010 02:25 PM
Quick Reply: Trailer Hitch wiring
