Help- H&R coilovers too high on front and cannot go lower
Old 11-15-2018, 04:17 PM
evdean's Avatar
evdean is an unknown quantity at this point
Had H&R coilovers installed today. Tech said the front (both sides) are maxed out on lowest setting and they are still setting the cars front very high. Anyone come across this? Ideas on whats wrong?
Old 11-15-2018, 04:33 PM
evdean's Avatar
coilover
Old 11-15-2018, 07:46 PM
evdean's Avatar
Is this the wrong strut for the turbo? C4?
Old 11-15-2018, 11:36 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
part number seems right
did the shop loosen control arm drop on ground/load weight and retighten?
Old 11-16-2018, 08:22 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Drive around to let them settle a bit and see where you are then.
Old 11-17-2018, 08:46 AM
Slider's Avatar
You might want to confirm what pieces they replaced at the top as well...
Old 11-17-2018, 10:23 AM
evdean's Avatar
Thx all. After speaking with h&r they confirmed all is correct. They hava had a small percet of 996s with this issue and are sending a shorter spring 30mm less with same rate
Old 11-17-2018, 11:00 AM
VAGscum's Avatar
Also verify that the front shock is all the into the spindle. Those shock should have a tab that stops the shocks that should be sitting against the top of the spindle.
evdean
12-10-2018 02:28 PM
Quick Reply: Help- H&R coilovers too high on front and cannot go lower
