2006 Continental lifting points
Just behind the front wheel and in front of the rear wheel are thicker wider square or rectangular spots. In the center of the lifting points is a rubber drain plug. I would recommend removing these plugs before lifting. The plugs sometimes crumble because Bentley used soy-based oils on rubberized plastic parts. Avoid using a metal jack saddle. Purchase a flat rubber surfaced lifting attachment for your hydraulic jack. When lifting, sometimes, the undercoating will peel off Lifting uniformly on each side and slowly Rising the vehicle is preferred to avoid undercoat damage. Jack stands can be strategically placed under the the wheel control arms.
Don't forget to put your car in "Jack mode" before you try to lift it.
