Sponsored by: Bears Transport
Electrical pin outs for purge valve
Old 03-19-2019, 01:47 PM
Kenith's Avatar
Kenith is an unknown quantity at this point
Looking to see if anyone has the ECU pinouts for the vent line purge valve? I'm getting a P0444 and an indy shop says the plug routed to that seems way too tight to be the correct plug. Does anyone have access to the ECU pinouts from this purge valve to the ECU? I found several ECU diagram PDF's but they do not show the wiring for this specific part.
Old 03-19-2019, 04:56 PM
Kenith's Avatar
If anyone has the full ECU pin outs, I can do the leg work to find the pins.
Old 03-19-2019, 05:16 PM
o7silverturbo's Avatar
o7silverturbo is an unknown quantity at this point
Im looking for you, I havent been able to find it on any wiring diagram
Old 03-19-2019, 06:25 PM
Kenith's Avatar
much appreciated sir! Not sure how this connector might have gotten mixed up.
Old 03-19-2019, 07:46 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Pinouts here: https://www.6speedonline.com/forums/...g-diagram.html
what you're looking for: C3 on the ECU side ... pin 9 on the first round connector engine side ... Violet/Violet wire
Old 03-19-2019, 08:02 PM
Kenith's Avatar
great! Thank you! Looks like I’ll be able to pin it from the two round harness plugs in the rear of the motor!
Old 03-20-2019, 06:08 AM
The connector prob isnt mixed up or you would have two codes because something else would be plugged in the wrong spot.
Also I found that same picture but I believe that is for the gas tank vent valve. That little valve you are looking for goes to the intake manifold so it should be the purge valve
Old 03-20-2019, 08:35 AM
Kenith's Avatar
that’s a good point, but I’m getting a p0444 even after the Indy shop replaced the purge valve and carbon canister. They mentioned the harness seems way too tight.
Old 03-20-2019, 11:35 AM
they replaced the purge valve in the engine bay? the picture that you posted?
Because I dont think on the 997 it has a tank vent valve. I believe it just has the engine purge valve
Old 03-20-2019, 11:59 AM
Kenith's Avatar
the pdf I posted is of the “tree assembly” which was replaced along with the carbon canister up front. The pdf I pulled was from a 997.1 turbo.
Old 03-21-2019, 11:08 AM
Kenith's Avatar
we’ll be tackling this project this Saturday, any other ideas on the P0444 cel? The car idle hunts (sometimes, with the cel coming on right after), with similar symptoms of a vacuum leak.
Old 03-21-2019, 12:11 PM
I checked on my car for you. Those wire match the colors going to the valve on my car so it seem the wiring diagram is right.
I would UNPLUG the valve and power it to see if it clicks. Make sure you didnt get a bad part from the dealer or part store.
Check resistance from the main plug to the sensor plug make sure you dont have a break in the wiring.
If you have access to a scanner can have a meter on there and see if the computer is even commanding the sensor on.
PM and Ill give you my cell number if you have any questions you can shoot me a text
Old 03-30-2019, 09:38 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
I replaced the vent hose in order to correct a P0455 code..
https://rennlist.com/forums/997-turb...l#post13542347
see post #13 and #19
Worked like a champ, I bet you have some other issue. The connector just provided 12V to cause the hose to flow air or not. Mine was easy to check.
dg930
05-25-2016 11:41 AM
clunker
04-28-2015 05:28 PM
ciaka
Cayenne 955/957
09-25-2012 09:38 AM
Quick Reply: Electrical pin outs for purge valve
