Topping off Pentosin
Hey all...just looking to to top off my power steering fluid. Is this fluid like ATF fluid that needs to be measured while hot or can it be done cold? Is there any special procedure I have to be aware of or anything?
Fill
There is a cold and a hot mark on the PS dip stick.
Note: if you PS is low check your front clutch fluid reservo to see if it is overfull. If it is you likely have a clutch slave cyl failing....fyi.
