40 K miles services for my 4S 2010
I got another from one indy shop for $1440 pre tax. And one from Bellevue Porsche around the same as the indy shop. Another indy shop quoted around $1000. This shop works mostly on BMW and MB, not much on Porsche.
I think I should select Bellevue Porsche. What do you think? Thanks all
Are you handy and have a good set of tools around? It is really easy to DIY honestly - probably total of $500 and ~3hrs time.
Plugs - can be done in less than an hour (I wrote a DIY on this forum and since then others have as well)
Air Filters - removing the bumper can be intimidating, however, again, super easy and just use caution to not scratch the paint. The in cabin filter takes about 5 minutes
Brakes - inspect them, I'm sure they're fine but you should consider a brake fluid flush (tool is super cheap at harbor freight or you can have a friend help)
Scanner - you'll need something to clear the maintenance light - the iCarsoft is pretty cheap and could help in the future regardless - think of this as an investment
(agree with above post from rmjjensen -- I have done all the maintenance on my Panamera myself -- it's not harder than any other car other than needing the scanner tool for reset)
I recommend that you get a detail list of what each dealership / mechanic is including in the price. There are several services that due to age are recommended for your car that may not be indicated/included due to lower mileage. (40K I assume) at 9 years of age.
(i.e., brake fluid change, spark plugs, PDK fluid change, air filter, ...)
Just make sure you are getting apples-to-apples comparisons and also that all the services you feel need to be done are being covered.
I don't have the 2010 maintenance schedule, but here is a copy of the 2014 version.
Regards,
Regards,
Regards,
Regards,
Unfortunately I am too old to DIY. My car has 37.5 K miles.
Yes. I asked them to give me a list of what they do for 40 K services. Cost of parts and labor.
Attached is the quote from AIR - indy shop.
Not a terrible deal, and I understand an indy marketing up parts but they are killing you on oil ($98 for 9.5 quarters - Amazing price about ~60) and spark plugs ($343/8 - amazing price about ~80 for a set) is a bit insane.
You asked if it's terrible - some parts are terrible and another indy may give you a better deal overall. So the answer is, it's bad. Not just compared to doing itself either. It's a high, a good indy likely does it for 50-75% of the cost.
Thanks. I’ll shop around more. Unfortunately there are not many indy working on Porsche in my city
Hopefully someone else in the area can make another suggestion.
You could try Rolf's. Not a Porsche specialist per se, but they do work on them and generally have a good reputation. It would at least be worth a second quote/opinion if nothing else to validate what you'd spend.
Porsche bellevue is very good shop in WA. I would go with Porsche in Bellevue, ask for 10% discount if they can give it to you to compete with Indy. For same price I go with Porsche for peace of mind. I bought my 2016 Porsche panamera S hybrid from bellevue even I lived in the SF bay area.
