'06 db9
Old 06-16-2019, 07:08 AM
Shooter Martin's Avatar
Shooter Martin is on a distinguished road
'06 db9
Hello, I own a 2006 Aston Martin DB9 and the doors raise up about 15 degrees when you open them (so as not to hit a curb) and was wondering if there was an adjustment on them to increase the tension on the spring because when the car is slightly inclined the door will not stay open ?
Thank you,
TK
Old 06-16-2019, 07:29 AM
J doubleU's Avatar
Common wear item that needs replaced. You should have not only the doors, but hood and trunk gas assist struts replaced at the same time. Quick search on here found this....
https://www.6speedonline.com/forums/...placement.html
Old 06-16-2019, 08:03 AM
DonL's Avatar
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Strut replacements
Here's another link with additional information;
gtmule
05-06-2021 07:42 PM
CarPoint
05-14-2013 01:28 AM
donahdi
06-28-2010 04:33 PM
Chordate
03-18-2004 01:47 PM
Quick Reply: '06 db9
