Stereo climate control display - weird lines looks cracked
Old 06-19-2019, 04:21 AM
topofthemorning's Avatar
topofthemorning is an unknown quantity at this point
Hard to take a picture in the daylight but the display seems damaged. It's not the surface that's scratched but it's underneath, looks like melted plastic (left and right corners). Apologies for the bad Pic
Any ideas?
Would a DB9 display straight swap in to my DBS?
Old 06-19-2019, 08:22 AM
J doubleU's Avatar
You can buy just the lens from Aston Parts, but yes a DB9 or even Vantage are the same as far as the lens. to change the control unit may not depending on what electronic package was fitted to the donor car. Just buy a new lens.
Old 06-20-2019, 01:30 AM
Took a closer look this morning. Unfortunately it isn't the lens (wish it was as it would be a straightforward swap). It looks like the layer under the lens next to that display. The display works fine.
At night it's not noticeable as the graphics/pixels appear fine.
Does this mean I need to get a new unit, if so can I just get a regular db9/vantage unit?
Old 06-20-2019, 06:25 AM
J doubleU's Avatar
It's in the lens, it's called crazing. Again if you replace the assembly with another used one all the features may not work. Do a search on here for lens replacement.
Old 06-20-2019, 06:31 AM
J doubleU's Avatar
Old 06-20-2019, 06:45 AM
thank you, I'll give it a try!
like7272
05-30-2021 10:43 AM
gary2220
06-25-2017 06:06 AM
Izzycab
06-13-2016 12:09 PM
RDH
10-27-2003 10:08 PM
Quick Reply: Stereo climate control display - weird lines looks cracked
