Regarding this condensation in tail light issue
Hi,
I can see that this is a problem a lot of people have faced with their Vantage.
If I source a used one, it will eventually have condensation ...
If I order a new one at the dealer it's nearly 2000$
If I look on ebay in the Aston Martin Work store they say they have a newer and imporved version that resolve any condesation issue ...
I am wondering because they are the same price for a pair from ebay compare to the price of a single lamp from my dealer.
Is it true AM did a newer version that won't condensate in the futur?
Any advice?
Any advice?
Please provide a link to the new and improved non-condensating tail light.. The original taillights, red or clear were produced by Magna in Canada. I had a set of 2006 build and replaced them with a set built in 2016 and there were no differences. .
I'm just happy that they are not DB11 tail lights at $8500 pair.
About 2016 they changed the adhesive that bonds the lens to the body for something more reliable. There’s zero difference structurally between them.
One of the most common causes of failure is When fitting the lights, some individuals pull the outer edge against the rear wing panel which causes the lens to leak. It could happen at anytime and the owner or future owners end up wither issue.
My 2017 V12S is a late build (a high VIN#) - both tail lights are bad - ordered new ones under warranty. My car was built (data plate) 06/17 so if the fix was in 2016 yu would think mine would not leak!
Has anyone had success with resealing these lights? One of mine is starting to show signs when I wash my car. I would rather fix them now if there is a reliable adhesive others have used.
I fixed any potential tail light condensation issue using the same approach used to fix the head lights, which ironically are made by the same manufacturer (Magna). Read here from Post #16 upward.
https://www.6speedonline.com/forums/...nsation-2.html
When I removed the original 2006 tail lights and examined them side by side with the new clear 2016 lights I could not see any improvements, but you say a new stronger adhesive may have been used? As I learned from reworking the headlights sealing from water penetration is only half the issue, letting the housing breathe is the second component that is necessary to avoid condensation. Like Matt in the thread linked, I’ve had no issues since reworking both headlights and tail lights and confidently drive in heavy rain and frequently wash the car without the concern I had prior.
Easy fix. Pull out tail light and drill 3 small holes holes in the bottom of the housing. Put a clear silicone around the housing to make it water proof. Within a day the lens should clear. I did this last month to my 2014 v8v. No more water condensation even when taken though an automatic wash.
This is what the post sale manager told me. Most are tightened too tight and it starts to pull the seal apart. I know they replaced mine 2 1/2 years ago and they're still clear. Now both headlights are a little fogged and one led strip is running at half power. I wish somebody would go into business fixing these things.
Well, they kind of have.
https://m.youtube.com/watch?v=2aEYC1EbCt4
I too have a problem with one of my LED headlight strips on my 2010 V8V; the light is clearly on but quite dim vs the other side. At times it comes to full brightness, at other times its right out. Tried to snake in a tube to the area and blow in compressed air with no result. this technique had been suggested in the shop manual. tried to blow air in via hairdryer. tried to pull the rear headlight access panel off and drive it for awhile, all to no avail. I wondered if this was an electrical connection problem vs a water problem. If its a water issue, i wonder why its periodic. Thought about drilling a small hole in the headlight and pumping air in that way
any insights would be appreciated Paul
Mine came back to full bright again Friday. It'll probably be out again the next time I notice, of back at half power. I would assume it has something to do with a bad contact or a capacitor going, but I'm not going to try and fix it because I don't have the diagnostic skill. Why I wish there was somebody you could just send these to to fix.
I believe the real problem is the adhesive silicon bead used is intermittent. it looks like a dashed line.How do I know - I've taken them apart to apply new consistent beads - you get an inch or two every few inches where no adhesive (silicone) was applied - the entire lens is affixed with an intermittent application of silicone adhesive. If you leave the tail lights in loose when installing you will keep a good plastic to plastic contact (where the adhesive is absent) that might help keep water out but you may not be able to match up the body lines with the outline of the exterior lens. If you pull them tighter to match the body lines the plastic lens and housing separate more where there is NO silicone adhesive - that's exactly what happened on the assembly line as installers matched the body lines with the curvature, and why they have failed direct from factory without ever being removed. and replaced by owners. .
Exact same on the headlights - intermittent silicone adhesive. One of the reasons both the tail lights and headlight lenses come apart so easily. I didn't even need a heat gun to pull these apart. Absolutely pathetic quality - I'll never buy another car that uses Magna lighting fixtures.
They're fixable though (both headlights and tail lights) but you have to address both issues: Moisture penetration resistance and internal/external air exchange.
