Pano 970 GTS - Need hi-flo cats like PTT!
We need Fabspeed or another aftermarket supplier to create a hi-flo cats down pipe for the Pano 970 GTS like they have created for the Pano TT. Mine is a 2015 GTS, I've installed a straight-flow x-pipe in place of the resonator, and that created additional great sounds and more flow. The next thing I would like is to be able to replace the down pipes but also have cats to pass inspections and not set off the check engine light. Alex Acuff (Fabspeed), is there any thought about Fabspeed developing this exhaust product? Thanks
No GTS owners with this desire?
Maybe this is why there is not an aftermarket replacement to reduce the number of cats from (2) on both sides to (1). This should increase the sound and HP to some degree. The developer would dyno the upgrade and determine the enhanced performance. Why is this only available to the turbo model?
Supply and demand, Moore. If the market can not/will not support a product to be profitable then very few, if any, logical companies would be likely to invest in production. An experienced exhaust shop can probably do something for the GTS cars.
Supply & demand, Moore. If the market can not/will not support the product then not many companies, if any, would risk development and production costs. An experienced exhaust shop would be able to do something for the GTS.
For my own '14 "S will probably use a Magnafow 49 state universal-fit 200 cell cat. I will have an exhaust shop cut the oem cat out and install/weld the Magnaflow in place. I will keep the oem cats for later usage when selling the car, etc. Total cost should be less than $500.
classic masonry
996 Turbo Vendor Classifieds
07-24-2012 06:05 PM
imolafem
09-09-2010 05:19 PM
