Downshifting the V12 just for the pops bangs and crackles - good or bad
I'm addicted to the paddles, especially to downshift my DBS. Is this bad for the engine and does this wear out the transmission/clutch?
- understand general wear and tear but just curious to know if it's detrimental.
Shifting and revving are what the car is made to do. Does shifting wear the clutch? Yes. Does high RPM wear the engine faster? Yes, as long as the alternative isn't lugging it which is much worse. But are you trying to preserve the car or enjoy it?
ZF 6HP transmission
The modern DBS uses the same automatic transmission as the DB9;
See the following post:
https://www.6speedonline.com/forums/...-question.html
Use the link in post #3 for more detailed information.
Forum search is your friend...
Wasn't aware that it was the same transmission as the DB9 thanks for sharing the post.
How about engaging in neutral (ie whilst coasting at a normal speed) in tunnels to blip the throttle. Does engaging neutral on the transmission damage it too?
Nothing that you're describing is going to damage the car.
Going from drive to neutral shouldn't cause abnormal transmission wear.
However, going from neutral to "drive", depending on what speed you started at, and at what speed you re-engage, and what mode you're in, could cause additional wear and transmission damage.
Don't know if your DBS has rev-matching in the situation I'm describing.
Drive as you like, but be advised that "showing off" can often lead to multiple problems...just my humble opinion.
Not showing off personally. my two year old in the back seat loves it when the exhaust goes off. She's like "wow" and has the cutest smile.
One of the multitude of reasons why we purchased an Aston Martin and enjoy driving the same .
I found that when going to neutral while moving mine never re-engaged any lower than 5th no matter what speed I was doing.
Discovered on my first track day that when I downshifted at too high an rpm the transmission basically waited till I had slowed a bit before engaging the next lower gear. No way to overrev when downshifting, at least on mine - 2009 DB9.
