FS: 2007 Corvette Z06 - Fully Built 447ci N/A - $35k
FS: 2007 Corvette Z06 - Fully Built 447ci N/A - $SOLD
Year: 2007
Make: Chevrolet
Model: Corvette
Price: $35000
Mileage: 43500
Color: Yellow
Location (State): AZ
Transmission: Manual
Drivetrain: Rear Wheel Drive
43,500 Miles
Phoenix, AZ
Asking $SOLD*******
Overview
I am looking to sell because I want to upgrade to a C7 Z06. When I purchased it, the car had fixed heads but was otherwise stock. Unfortunately, the rod coating issue (a known issue to LS7 engines) happened right after I purchased the car, leading me to need to rebuild the engine. Rather than just spend a few grand and keep it mostly stock, my mod list snowballed hard and I fully built this car as a N/A beast.
The car is fully built, you can see the mod list below, and currently has about 1,400 miles on the new engine. It made 623whp/547wtq on E85 and about 5whp/5wtq less on 91 octane. The car runs on flex, so anything between 91 octane and 85% ethanol fuel can be used.
The exterior of the car is in excellent condition. There are a couple small chips on the hood and a some nicks around the rear quarter panel brake ducts. There is also a small nick that has been touched up on the rear hatch from the previous owner. The car could use a paint correction because of some swirls, and if that is something that you are interested in I could have something arranged before delivery. The tires are 75%+ tread life remaining and they still pretty much hook in 2nd for the most part. The interior of the car is also in excellent condition, with only a small amount of wear on the driver bolster. The audio system has been upgraded with a headunit, speakers all around, amplifier, and JL subwoofer stealth box. Mechanically, the car is basically brand new. Clutch engages smooth, no signs of slipping. The transmission and drivetrain is other stock. The engine has no weird noises or oil consumption issues. I just did a leakdown test and oil analysis with good results. The car pulls very hard and sounds amazing.
Leak Down Test
1: 3.7% 2: 5.4%
3: 1.8% 4: 6.9%
5: 7.1% 6: 6.9%
7: 5.4% 8: 7.1%
You are getting a lot of value in the parts on this car. I built it to be reliable in the hot weather here in Arizona, but also something I could beat on and stay reliable. I also did some mods in preparation of doing some hpde and autocross.
I have the full maintenance records (very extensive) going back four years.
Modifications
Engine (447ci, ~12.5:1 CR)
- Short Block (OEM LS7 Block machined)
- Blueprint Specs
- Fully balanced and plate honed
- PTW: .0035-.0038
- Main Clearance: .0024, .0023, .0022, .0022, .0023
- Rod Clearance: .0024-.0025
- Upper Rings: .018-.019
- Lower Rings: .020-.021
- Pistons: 4.1514-4.1515
- Crank Main: 2.5338
- Crank Rod: 2.0995-2.0996
- Rod Small End: .9280-.9281
- Rod Big End: 2.2250
- Blueprint Specs
- Darton Dry Sleeves
- Callies Compstar Crankshaft 4.125” Stroke, 58x, Long Snout
- Callies Compstar Rods 6.125”
- Wiseco Pistons 4.155” Bore, 4.125” Stroke, -2.8cc
- Upgraded Piston Wrist Pins
- CPR Custom Camshaft - 254/266 116 .658/.658
- King XP Rod Bearings
- King XP Main Bearings
- Durabond Coated Cam Bearings
- ARP Main Studs
- ARP Cam Bolts
- ARP Balancer Bolt
- ARP Head Studs
- Johnson 2110R Lifters
- Katech C5R Chain
- New OEM Gaskets
- LS9 Crank Sprocket
- LS9 Oil Pump
- Powerbond Race Harmonic Balancer (OEM Size)
- New OEM Timing Dampener
- WCCH Stage 2 CNC Ported Heads, 69cc
- Comp BSR Solid Rockers
- Manley Titanium Cr/Moly Intake Valves
- SS Exhaust Valves
- Manton Series 3 Pushrods - Custom Lengths
- BTR Platinum Valve Springs .685” w/ Titanium Retainers
- Cometic .051” 4.190 bore MLS Head Gasket
- Prospeed Dual Fans
- Mast Stroker Windage Tray
- New OEM Oil Pickup Tube and Gasket
- New OEM AC Condenser
- New OEM MAF Sensor
- New OEM Accessory Belts
- New OEM Cam Position Sensor
- New OEM 185 degree Thermostat and Seal
- New OEM Spark Plug Wires
- NGK TR6 Spark Plugs @ .38
- LPE 10qt Dry Sump Tank
- Mighty Mouse Catch Can “Wild”
- Holley LS Valve Covers
- Improved Racing Oil Pan Baffle
- Improved Racing Oil Thermostat 212 Degree
- Hinson OEM Height Motor Mounts
- American Racing Headers 2” w/ 3” Xpipe
- Airraid Intake
- MSD LS7 Intake Manifold
- NW 102mm Throttle Body
- Tuned by UMS Tuning on flex 91/e85
- Walbro 450 Fuel Pump
- Racetronix Full and Intermediate Fuel Wiring Harnesses
- DSX Flex Fuel Setup
- FIC 60lb Fuel Injectors
- Monster LT1-S Twin Disc Clutch
- New OEM LS Pilot Bearing
- New OEM Flywheel Bolts
- New OEM Throw Out Bearing
- Remote Clutch Bleeder
- MGW Shifter
- DRM Valved Bilstein Struts
- ZR1 Rear Swaybar + Bushings
- Carbotech 1521 Brake Pads - Front
- MTW Exhaust Controller
- Muffler Mod on OEM NPP Exhaust
- MRR M775 Wheels 18”/19”
- Michelin Pilot SuperSport Tires 285/345 Combo
- ZR1 Front Lip - Black ABS Plastic
- Front Fascia Bumper Reinforcement
- Black Painted Headlights + New RLSebring Lenses
- Morimoto Tailights
- New OEM Fog light Housings
- Full-width Spoiler
- Blend Mount/Mirror Tap for Radar Detector
- AEM X Series Wideband installed in glovebox
- JL Audio Amp w/ enclosure
- Pioneer AVHX491BHS & Sirius Tuner
- Pioneer TSZ65F Coaxial Speakers
- Pioneer TSZ65CH Speakers
- Rockford R500x1D Amp
Videos
1)
vman932
Jun 4, 2017 12:31 PM
scott240
Sep 28, 2014 07:41 AM
