Defective wheel / Flat tire error msgs
Hello,
I have started getting weird error messages on my screen when I start my car. One is "Defective wheel", what in the world is that? And immediately after that one goes away I get a red "Flat tire" error message that doesn't go away. All tires are inflated properly...
It is an '07 with about 7,000 km. I do not have a complete owner history as it was imported from Japan, but I don't believe that much of the original parts have been replaced thus far.
So the wheel sensors have batteries? That is news to me. I supposed I should have figured that one out, though, but I've really never given them much thought. Can VCDS help me pinpoint which one it is?
Thanks.
I just replaced the original batteries on my 2013 GTC (they had a 2012 production date).
So far the TPMS is remarkably accurate when checked against a good manual pressure guage.
I guess I will know when the TPMS batteries go as I would get erratic or no read out on my console.
I kind of like following the readings on the TPMS as I drive. Any idea of a part number or reference?
They don't show up on a couple of the on line suppliers.
I'm not sure why you would use generic ones when the VW/Audi sensors are so cheap (obviously not so much so if they come in a box marked "Bentley"), and the car is immediately interoperable with them?
Once the TPMS modules are changed, might as well do all four. You will have to do a reset.You'll have to do some research on which MHz they are.
I think my Durametric will indicate which I have.
It's more of a LEARN, its in the Digital Instrument Control, using the Stalk on the steering column.
Relearn instruction
No special tools are required to perform this relearn procedure.Sensor Relearn Procedure:
- From the main TPMS menu (i.e. showing all your pressures):
> Access menu by tapping forward with multi-function stalk (located lower right of steering wheel), or by pushing down right-side multi-function ball on steering wheel (if equipped).
> Navigate down to “Tire type” field; tap forward again
> Select tire type and tap forward again (depending on your car it’ll show different options: my car—for instance—has options for “20" Summer” or “20" Winter”; choose whichever option is applicable to your case)
> Tire selection will only be completed successfully when the following message appears on the display: “No tire pressure monitoring System is learning”
> Drive around a bit and the system should figure everything out—the wheel learning process takes place when the vehicle is being driven with a vehicle speed above 16 mph (25 km/h)
> During this time, current tire pressures will not available on the multi-function display:
– The tire pressure warning light will remain lit until all wheels have been learned.
– Lines (-.-) will appear on the display of the “TPMS” function.
– Required pressures for cold tires 68°F (20°C) are shown under “Fill info” in the “TPMS” main menu.
All this can be found in the “Instrument Panel and Multi-Function Display” section of your owners manual.
