Porsche 986 boxster for sale
Old Jul 9, 2024 | 08:13 AM
Xupherix's Avatar
Xupherix
Looking to sell my 1998 porsche boxster
$15000 or best offer
[[SALVAGE TITLE]]
1. New tuneRS 2qt engine oil sump expansion.
2. New tuneRS Under drive pulley.
3. New AOS+Tubing.
4. New MAF
5. New Life time Air Filter by B&M.
6. New LN Engineering metal oil filter adapter with bosh filter.
7. New Sachs Clutch.
8. New Sachs pressure plate With new plate bolts.
9. New LuK Dual mass flywheel With new stretch bolts
10. New throwout bearing.
11. New Ball pin for clutch release.
12. New Clutch release Lever.
13 New retaining spring for clutch release lever.
14. New Guide tube for clutch release bearing with new seal.
15. New main shaft seal
16. New Pilot Bearing
17. New pivot piece for clutch release lever
18. New RMS with camshaft end plugs
19. New IMS with New Ims flange
20. New coolant resivior with new sensor and caps.
21. New water pump with Hoses and new drain plug
22. New thermostat.
23. New 987 engine motor mount.
24. New Wevo Semi solid transmission mounts.
25. New change over Valve.
26. New secondary air injection check valve.
27. New Cut off vavle air injection.
28. New Brake Booster vacuum link with check valve.
29. New Bosh Impulse sender.
30. New Beru Spark plugs with new tubes and ignition coils and all new seals.
31. All brand New idler pulleys and tensioner pulleys.
32. New Fuel Filter.
33.New chain tensioner seals and crush washers.
34. New Bilstein Pss9 Coilovers
35. New tarrett sway bars front and rear.
36. New Tarrett adjustable drop links front and rear with rubber boot covers(+weight)
37. New all 4 wheel bearings packed with CV-2 high temp grease.
38.NEW R1 concept slotted rotors front and rear
39. New parking brake shoes with new springs.
40. New TuneRS Power steering cooling radiator.
41. New tuneRS adjustable rear toe arms.
42. New window regulators both sides.
43. New Door lock mechanism driver side.
45. New 40mm H&R rear wheel spacers.
46. New 15mm front wheel spacers.
47. New Gt3 lug bolts (50mm long)
48. New Rsr gt3 Control arms front and rear.
49. New passenger seat belt receptacle
50. New ignition switch.
51. New axles both sides with new axle nuts and 8x50mm bolts
52. New shift boot retaining clip
56.19 INCH BBS LM reps one piece rims(no idea what brand)
57. Porsche boxster hid
58. Porsche 997 shifter with **** with short shifter kit.
59. New porsche boxster shifter cables.
64. American international racing rear 2 inch rear fenders
66. Upgraded to RB PERFORMANCE and rebuilt brake caliper pistions front from smooth circular to teethed and high temp pistion covers for the front.
67. Rebuilt rear brake calipers.
68. Powdered coated white rear brake calipers.
70. 996 headlight corners
71. New headlamp switch
72. Stormski racing bump steer
73 tuneRS bump steer.
74. Godspeed front and rear adjustable track arms.
75. Powerflex polyurethane front sway bar bushing 28mm
76. Powerflex polyurethane rear sway bar bushing 19mm
77.997 front end conversion
78.Misha front bumper customize to fit boxster
79. 991 gt3 louvered fenders fits 986 boxster
80. Misha 997 hood fits 996 boxster
NEEDS
TOP
997 headlights
Paint
Newowner
the_vetman
Aug 13, 2019 03:06 AM
eyespy71
Feb 28, 2018 12:29 PM
Mike2727
May 28, 2014 08:12 PM
GT3 Chuck
Aug 1, 2010 03:39 PM
