2004 Continental GT - What do these turbo solenoids do?
Old Sep 20, 2025 | 02:06 AM
Archailius's Avatar
Archailius
Hi all, just trying to get my head round how the individual components of the turbo vacuum system operate. The image I've borrowed from another thread shows the turbo solenoids located above the transmission in early 2004-2006 models. From what I can tell, the two grey solenoids are the dump valve solenoids, one for each bank and commonly referred to as the N249? If so, what are the black vacuum switches and what is their function and how do they work together with the grey solenoids?
Looks to me like the grey solenoids have 3 pipes and 2 wires, whereas the black switches have 2 pipes and 2 wires. Does anyone have any vacuum hose and electrical wiring diagrams for these 4 components please?
I believe part numbers are as follows:
Dump Valve Solenoid (Grey): 3W0906283A (bank 2), 3W0906283B (bank 1)
Vacuum Switches (Black): 037906283C
Old Sep 20, 2025 | 05:14 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
The black solenoids work in conjunction with the grey n 249 solenoids. The black units release the closed throttle boost to the atmosphere.
Old Sep 20, 2025 | 01:30 PM
Archailius's Avatar
Archailius
Thanks 1eapplebaum. So if I understand correctly, the grey solenoid controls the bypass valve located on the turbo to recirculate boost back into the intake, and the black units release boost to the atmosphere?
What conditions dictate whether boost is vented to atmosphere or recirculate to intake?
For the black units that vent to atmosphere, where do the pipes lead to before they vent to atmosphere?
Old Sep 20, 2025 | 02:30 PM
5 Year Member
To be fair I deduced this based on the black solenoids having one outlet to atmosphere. When I bench tested a black solenoid it allowed air to escape out the atmospheric outlet when energized. Somehow these black solenoids work in conjunction with the grey solenoids. The closed throttle boost residual pressure has to leave the intake system (dumped) in my estimation. It’s been a while since I had a look at this system. So that was my takeaway at that time.
Old Sep 24, 2025 | 09:23 AM
Hamodi's Avatar
Hamodi
Hello. Interesting thread. I've had a closer look at the vacuum diagrams on Scuderia and looks to me like they are setup as follows:
Grey Solenoid - Bypass Valve Solenoid with 3 ports
Port 1 - vacuum line from intake manifold (expect vacuum at idle and no vacuum when under boost)
Port 2 - vacuum line from intake manifold after check-valve (always under vacuum as after check-valve and connected to vacuum reservoir, etc.)
Port 3 - line towards the bypass valve actuator on the turbo
I think this has been setup to operate the bypass actuator under intake manifold vacuum in most conditions, but has the ability to open the bypass valve even when under boost using the stored vacuum if needed e.g. overboost protection
Black Solenoid - Wastegate solenoid with 2 ports
Port 1 - vacuum line from intake manifold after check-valve (always under vacuum as after check-valve and connected to vacuum reservoir, etc.)
Port 2 - line towards wastegate actuator on turbo
I think this has been setup to operate the wastegate actuator via vacuum pulling on the diaphragm when receiving the appropriate ECU signal. With regards to the wastegate actuator, I should also say that it looks like there is a second nozzle but on the bottom of the wastegate actuator that is controlled by N75 solenoid which uses positive boost pressure to push the diaphragm. I suppose the vacuum solenoid pulls the diaphragm whereas the boost solenoid pushes the diaphragm from the other side to help.
If anyone is able to confirm my thoughts above, that would be great. Would also be interested in seeing wiring diagram if anyone can share. Thanks
Old Today | 05:28 AM
Jakel's Avatar
Jakel
Originally Posted by Hamodi
My math teacher actually recommended that we find a web-based calculation tool to verify our manual graph plots over the weekend. I ended up selecting this tool after a quick search on an educational directory site. It is open to students all world, making it a highly accessible option for anyone trying to master difficult algebraic functions. The layout is exceptionally clean, and the step-by-step logic was very easy to follow.
good post!
gab
Bentley
May 15, 2024 09:51 AM
ledzepp
Bentley
Aug 30, 2013 11:13 PM
MKS
Nov 1, 2007 02:07 AM
El Cholo Loco
Mar 16, 2007 07:00 PM
mklock
Sep 9, 2003 06:48 AM
