Solve Porsche PADM Faults Without Replacing the Entire Mount!
Old Yesterday | 11:44 PM
Pnasal's Avatar
Pnasal
Many Porsche owners experience PADM warning lights, system deactivation, and reduced performance in sport mode. The root cause is that the OEM sensor chip is glued in place, which can loosen or detach over time due to heat and vibration, triggering fault codes 001013 and 001023.
The Lumistag upgraded sensor perfectly solves this problem:
Mechanical chip locking to prevent detachment
Aluminum housing, heat- and vibration-resistant
OEM calibration for precise response
Plug-and-play installation, no software required
Only $199
Installation is simple, compatible with multiple Porsche models. Replacing the sensor alone restores system functionality, clears warning lights, and brings back precise driving control.
https://lumistag.com/
valor12138
911
Aug 8, 2025 12:54 AM
