Sprint Booster V3 - Eliminate Throttle Lag
Has anyone experienced throttle lag or hesitation?
Are any 6speed members familiar with Sprint Booster? If not, Sprint Booster is an easy to install, plug-n-play device that reprograms the acceleration signals in your stock ECU. So, when you press on your cars accelerator – you’ll immediately know it because your car INSTANTLY responds. You hit the gas and GO, no throttle lag, no hesitation. https://cimg2.ibsrv.net/gimg/www.6sp...89b24c2b4e.png |
Don't Let A Wire Ruin Your FunDrive-By-Wire systems could be robbing your car of performance and how it should feel when you drive it. Some of us are old enough to remember a time when cars had carburetors and mechanical throttle linkage. If you've ever driven an older car, lets say an early Mustang, you'd probably notice how responsive the vehicle is. That's because instead of having a "drive-by-wires" they had throttle cables.These throttle cables gave the car instant response from when you push the gas pedal and when the engines picks up the signal. Nowadays, all vehicles are made with drive-by-wire systems, which basically regulate how your car drives. It's like your car is being governed by who makes it. And that's exactly what automobile companies are doing. The drive-by-wire system was created to help improve our gas mileage (so does a Sprint Booster, read here) and help prevent emissions. |
