Wheels/Tires
Fixing Curbed Rims w/ Dremel tools
Old Feb 12, 2008 | 02:42 PM
xknowonex's Avatar
xknowonex is infamous around these parts
Hey guys I curbed my Work rims the other day while squeezing into out of a parking spot in Laguna and I want to fix it myself since I have a Dremel tool in my garage.
Have any of you guys tried to fix it yourself with a Dremel before?
If so, which bits or accessories for the Dremel should I pick up to perform the repair?
Old Feb 12, 2008 | 03:09 PM
glowone's Avatar
glowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to behold
curb rash
If they are polished aluminum not a problem.
Polishing aluminum is really simple. Start with a 180 grit sand paper, move to a 240 then up to 400. Add polish (with a dremel if you want) and whoalla...polished aluminum.
Keep in mind that it is a skill to get it down right. For a little curb rash its a DIY job (assuming that you have 1-2 hours to spend on it making it look good.
Or take it to an aluminum polishing shop and they will make it look perfect for not much $$$
Old Feb 12, 2008 | 05:15 PM
xknowonex's Avatar
Yea its polished aluminum with no coatings whatsoever. I'll just do that at low speeds and I'll use thick duct tape to mask off the the tire and the surrounding area of the wheel
Old Apr 18, 2008 | 05:37 PM
silversurfer22's Avatar
silversurfer22 is infamous around these parts
Did you ever fix your wheels? Maybe we can make this a mini meet cause I have curb rash on 3/4 wheels
Old Apr 21, 2008 | 09:10 PM
INI's Avatar
INI
INI is infamous around these partsINI is infamous around these parts
Ditto what glowone said...i have fixed a Crub rash wheelon my 7 with 22s ACS wheels and im going to be doing it soon on my neighbors...if you in OC area i dont mind showing you how to do it and you can even see the work in progress.....
Old Apr 21, 2008 | 09:16 PM
JT3's Avatar
JT3
JT3 is infamous around these partsJT3 is infamous around these parts
Which Work's do you have, are they stepped or cast?
I slightly curbed my old Volks (forged) and repaired using a dremel and all the standard attachments it came with.
My wheels were powdercoated white, so after I smoothed the rash I did a few coats using auto touch up paint and applied a clear coat. Worked like a charm.
Old Jun 5, 2008 | 07:44 AM
wheeltectampa's Avatar
wheeltectampa is infamous around these parts
good luck.
Rguy
Apr 12, 2020 11:11 PM
Texas1
Sep 20, 2015 09:12 AM
BLKMGK
Sep 19, 2015 03:51 PM
Nuke
Sep 8, 2015 09:09 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
