Wheels/Tires
Will 997C4 19" wheel fit a 997 Carrera?
Old Oct 5, 2006 | 01:16 AM
narbo's Avatar
narbo is infamous around these parts
I am getting my new wheels soon and my co-worker wants to buy the stock wheels ( 19" C4 ) for his 997 carrera.
Will it work or is it too wide? Will it stick out?
-nick
Old Oct 5, 2006 | 10:46 PM
jhbrennan's Avatar
-nick
What do you meant by stock - Classics, Sport, S? Most likely the offsets will different for the rear between C2 and C4. You can go to www.1010tire.com and use their offset calculator to see what happens. On Posche wheels the rim width and offset are stamped on the rim around the valve stem. For example the front will read 8 and 57 and rear will proably be 11 and either 51 (C4) or 67 (C2). If he's going from 51mm (C4 rear) to a C2, they'll probably stick out 16mm.
Old Oct 10, 2006 | 12:05 PM
raffi's Avatar
raffi is infamous around these parts
narbo, they will be fine,
the fronts are the same wheel, the rear is 16mm more aggressive. I had 15mm spacers on my 19's on narrow body and it looked fine, they did have the 295 tires though.
2lflat4
Nov 18, 2019 05:05 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
