Front Differential Chewed due to incorrect wheel/tire se up
Rating: Thread Rating: 9 votes, 5.00 average.
Old Oct 15, 2008 | 12:02 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Ok it seems my front differential/viscous coupling is chewed as I have put winter tires on my Cargraphic 19's and they are a differential profile to the the summer ones, a similar issue to trying to put 997 TT wheels on a 996 TT it seems, you can do it but soon or later you will also knacker the 4WD drivetrain.
Old Oct 15, 2008 | 12:23 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
What sizes winter setup have been used?
Old Oct 15, 2008 | 12:27 PM
RCH's Avatar
RCH
Ray it seems the Rear doesn't matter, I have had both 315/25 ad 305/25, the rule is simply for the Fronts don't go anywhere from 235/35's. Any experience with yours, what sizes have you got on your Cargraphics, ever had any winters ?
Old Oct 15, 2008 | 01:39 PM
ard's Avatar
ard
WHAT SIZES AND BRANDS WERE YOU RUNNING front and rear?
What matters is the mis-match between front and rear, not the absolute size of the fronts...
I'd heard you want to be within 0.3" in total tire diameter between front to rear....curious as to what your mismatch was that led to the diff issue...
A
Old Oct 15, 2008 | 01:51 PM
Ray's Avatar
Ray
My TT is running conti 235-35-19, 315-25-19 now. And the pevious owner ran 295-30-19 at the back. When I do the calculation, 295-30-19 is 1" full inch taller than stock 18" and my 315 is 0.3" taller than stock. I know he ran that 295 setup since new and from the service record, it don't have any problem. So with your 315 or 305 setup, it shouldn't eat up your diff.
Old Oct 15, 2008 | 02:14 PM
RCH's Avatar
RCH
tvm Ray for your input, my problem is that it seems I do have something other than 235/35's on the front and I won't know this until tomorrow am as all my docs are in the car, hence where my problem lays, the front axle.
Old Oct 15, 2008 | 02:25 PM
Joe Weinstein's Avatar
everything matters (front and rear). Post the complete tire spec, front and rear.
(brand, model, and size designation). The relative diameters are what matters.
Then go to www.tirerack.com, and look at the specific spec sheet for these
tires to see the actual diameter. I want my tire diameters to be equal to within
a few tenths of an inch, and if any difference, I much prefer the fronts to be
the taller.
For this viscous system, though, the closeness is the crucial part. Otherwise it's
like letting your clutch slip all the time. Quick burnout guaranteed.
Old Oct 15, 2008 | 02:36 PM
Divexxtreme's Avatar
the taller.
Joe,
You really need to post more often, bro. You're a wealth of good info.
Old Oct 15, 2008 | 02:57 PM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I recently bought a set of HRE's made for a 997TT. 19x9 and 19x12....
I spoke with HRE before purchasing to make sure there is no issue with rubbing or otherwise. They said I should be fine with my tire sizes and fitment with my PS2's.
I put my PS2's on them 235/35/19 and 315/25/19... I only have around 500 miles on them total....
Do you guys think I will run into this issue too or am I ok?
Old Oct 15, 2008 | 03:15 PM
msv's Avatar
msv
msv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to behold
You will be fine. With those tires, the revs per mile are 817 front and 824 rear, so within 0.8%, which is practically ideal.
Old Oct 15, 2008 | 03:55 PM
ard's Avatar
ard
So from PS2 specs (every tire CAN have different specs, even with the same nominal dimensions)
#1. 235/35-19 is 25.5 inches - revs per mile 817
#2. 315/25-19 is 25.2 inches revs per mile 824
#3. 295/30-19 is 26.0 inches revs per mile 799
You can see that running the first and last will cause the front diff to run ~ 2.5 times as much as #1 with #2.
Note that stock sizing has only 3 revs per mile difference... so the 18 revs per mile (on #1 with #3) is 6 times the stock size.
A
Old Oct 15, 2008 | 04:35 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
I've got a front dif and drive shaft for sale if anyone needs it. :0
Old Oct 15, 2008 | 04:45 PM
turbo turbo's Avatar
turbo turbo is infamous around these parts
if you put stock 08 turbo wheels and tires on a pre 05 turbo will you have trouble with the front rear wearing out?
Old Oct 15, 2008 | 06:33 PM
rdf16's Avatar
rdf16 is infamous around these partsrdf16 is infamous around these parts
I believe that's more of an offset issue, you will need spacers.
RD
Old Oct 15, 2008 | 07:11 PM
tom kerr's Avatar
when mine went I went to RWD.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
