Front Differential Chewed due to incorrect wheel/tire se up
Rating: Thread Rating: 9 votes, 5.00 average.
Old Oct 21, 2008 | 08:57 AM
  #46
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
lots of useful information, subscribed
i'm kindof confused now. i know lots of people run 235/35 19 and 315/25 19 (since i thought that was the stock GT2 setup?)
so i'm running 235/35 19 and 315/25 19 on Yoko AVS Sport (old tires, I don't even think they make them anymore) on TechArt wheels, is the combo that I'm running incorrect? i don't want an expensive repair bill for my differential
Old Oct 21, 2008 | 09:00 AM
  #47
wross996TT's Avatar
Jason, I have been running that size combo on Advan Sports for over a year...no problemo.
Old Oct 21, 2008 | 09:38 AM
  #48
WheelEnhancement's Avatar
WheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant future
Jason,
The tires that you are using, 235/35 19, 315/25 19, are the correct sizes for the 996. Using the correct diameter tires is very important on the all wheel drive cars as front differential damage will occur. The 997 GT2 uses 235/35 19 and 325/30 19.
Old Oct 21, 2008 | 10:04 AM
  #49
Joe Weinstein's Avatar
Originally Posted by Onibas
I still have not decided after your explanations.
I have a 997 TT wheels.
Can then be mounted to a 996 TT S cabrio?
Probably OK.
That should put tires?
Yes. We all recommend using tires. As above,
whatever you do, make sure the fronts and
rears are very close to the same documented
diameter.
That should put spacers?
For appearance, as you want.
Affect the mechanics of the car?
19" wheels will make the ride harsher, and put more
shock load on the shock-absorbers. Spacers are
not recommended for ultimate mechanical stability
but for cruising around they should be fine.
Old Oct 21, 2008 | 10:11 AM
  #50
Yes 997 Turbo wheels will work on 996 Turbo. The correct tires are 235/35 19 front and 315/25 19 rear. Yes you should use spacers. 5-7mm front and 7-15mm rear. The ride will be firmer due to the shorter sidewall of the tire. Turn-in will be sharper however you will sacrifice some grip at the limit and under acceleration out of a corner.
Old Oct 21, 2008 | 10:52 AM
  #51
landjet's Avatar
Alan, how are 235/40/18 and 315/30/18 for a 996TT? 235's are 25.4" and 819revolutions, and 315's are 25.5" and 817 revolutions. If these sizes are not correct, what would you recommend for 18" stock wheels?
Old Oct 21, 2008 | 11:09 AM
  #52
ard's Avatar
ard
Hi Alan- By this you mean the 997TT wheels will work, but not '997TT stock tire sizes'..correct?
Just trying to avoid confusion.
A
Old Oct 21, 2008 | 11:11 AM
  #53
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Fine to use that size
Old Oct 21, 2008 | 11:14 AM
  #54
A
Yes that is correct, 997 Turbo wheels will work, 997 rear tires will not.
Old Oct 21, 2008 | 11:48 AM
  #55
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
It will cost you $5,000 incl. labor if you get it wrong !!!!
Old Oct 21, 2008 | 01:46 PM
  #56
Onibas's Avatar
Onibas is infamous around these parts
In reference a front viscous differential crash????
Old Oct 21, 2008 | 01:49 PM
  #57
Onibas's Avatar
Many thanks, Joe and Alan.
Old Oct 21, 2008 | 02:32 PM
  #58
Onibas's Avatar
Alan, the 996 TT brings factory 5mm front and 15mm rear spacers in the sportechno wheels 18 originals.
Wich is your recommendation spacers in the 997 TT wheels change?
I can used this spacers in the news wheels?
Old Oct 21, 2008 | 02:48 PM
  #59
angldrkns9's Avatar
my car came with factory sport techno wheels 18" originals. i recall only 15mm rear spacer, no 5mm front spacer
Old Oct 21, 2008 | 03:32 PM
  #60
Onibas's Avatar
Thumbs up
Sorry, is true.
Hope the Alan request.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
