Refurbished Bosch Alternator installed and found a leak under the expansion tank
So I finally replaced my alternator that was acting out, after I keep changing my battery, but I found a leak under the expansion tank, I am wondering if I need to replace the entire housing?
It could be numbers of things that causes the leak. If your expansion tank & cap is still original, there might be a hairline crack that leaks under high pressure. Very common in the 996. Check the fitting where the pipe connects. Could be a loose clamp(s) maybe? G/L
titannero
Nissan GTR Vendor Classifieds
02-02-2016 10:27 AM
