Dension 500S BT install
#61
If you have any issues with your Dension, you may want to try this latest release. 0047 now ready to go.
Attachment 223360
Attachment 223361
Please remember, if you have any issues after updating, follow the install guide to revert back to previous version (0046). Full log of updates will come when Dension posts this on their site, but we have it now for release to customers.
And just so you know, Dension is fast at work on 0048 for some enhancements, we expect to see sometime in April/May.
Attachment 223360
Attachment 223361
I'm a bit late joining this thread, but have just bought Dension GW52MO2 to fit to my 997T / PCM2.1 with CDC & phone unit.
I took it to local installer who offered to fit it but gave up saying I needed a fibre extenson cable, which I don't believe....
I'm looking for instructions on the install.
I think I should be able to mount it behind the head unit, & plug the Dension in-line with the MOST feed to/from the CDC.
Do I need to unplug/loop/disable the factory phone under the seat?
Any help very gratefully received !
Kegscy
#62
Hey everyone. I just installed a 500s bt in my 997.1tt and am having a few issues. Sometimes it says no cd changer and won't recognize the dension at all, other times it works by playing audio through the iPod cable or flash drive. When the PCM does recognize the dension I can make Bluetooth calls but I have never been able to stream music to the unit over bluetooth. Any help only either issue?
Thanks, Seth
Thanks, Seth
#63
Dension 500 BT
Thanks, Seth
Thanks, Seth
I removed the CD changer & got the latest firmware for the Dension (5.0). Most times it does recognise the Dension, and I can use the 3.5mm i/p & BT phone. (or iPod) Occasionally it loses the lot and so I lose all radio/PCM, but I suspect this is a fibre link intermittancy, - its only happened 2 or 3 times though & is usually OK after a power cycle. Normally it gives a 'no CD changer' error which needs to be acknowledged, but DOES work.
I only ever got the BT Audio working once, and that was by *disabling* the BT phone !!
I am living with it for now, but I suspect I will replace the whole unit with something decent in the near future
I think its simply not robust enough/hasn't been properly tested with the Porsche system.... I guess you get what you pay for....
..unless anyone else has a magic fix....???!
Kegscy
#64
Seth, - that is similar to what I get.
Kegscy
Kegscy
Edwin
#65
I sure hope the final answer is not that we own a crappy product that doesn't function well. I like the bluetooth and the audio is clear, when it works. Hopefully I can get it working.
#67
If you purchased from us, reach out via email for any support: eric@bumperplugs.com
Some of the issues listed above are related to installation errors, setup errors, or failed programming. Usually simple to resolve.
If you bought elsewhere, go to your source for the unit for all support, and if they fail to provide it, get on Dension's website and report it, and create a ticket.
We're here for our customers and happy to help.
#68
Eric,
I wish I would have checked the forums prior to purchasing, I would have anticipated issues and purchased from you. The lastest software is installed and I replaced the nav-tv that was in my car with the dension. I figured it should work just as well as the nav-tv since it was pretty much the same wiring.
#69
Pull PCM and unclasp the wiring - one for MOST, 1 for PCM, 1 for power, and 2 for the antenna.
Hook up appropriate MOST wiring.
I decided to reuse my wiring harness from the GW500. I also had a custom wiring harness to tap power so I didn't have to wire tap directly into factory wiring.
#70
Passenger side footwell power socket. Unswitched power there. You don't need to splice wires in there. Just get a pin connector and solder it to the pos and neg. wedge the pin connectors on the same side as the oem wires into the harness.
#71
Dension s 500bt optical loop drawing please
Hi mate
Just fitted one of these densions s bt500 to my 997 turbo its a 2007 car and i think i might take a hammer to it ha ha
I have it all fitted but cannot sort the optical loop i think this is the problem my car has bose nav phone prep cdc
If i put a loop in the cdc isnt this the part of the nav to?
Dont want to lose my sat nav
Is there any proper info out there like a detailed drawing of what connects where regarding the optical bit
Thanks again
Thanks again
#72
Hi mate
Thanks again
Thanks again
Hope that helps? I may be able to find a pic or two later, if that does not make sense?
Good luck...
DC
#73
Eric,
Email me: info@bumperplugs.com
If your Porsche did not have a cdc, then it needs programming to ID the loop and each module. If it does have a cdc, and the Dension is not near the CDC or the CDC is not connected to the Dension's second port (assuming you purchased the dual port unit we sell), then there are going to be numerous issues.
For others, if you don't have detailed support from your reseller, report this to dension via their website (dension.com) and create an e-ticket. Dension needs to hear from customers about resellers not supporting their customers/products. And if you have not followed the specific installation guidelines, you can experience issues. For most, if the setup and installation guidelines are followed to the letter, these units work just fine. But you have to follow the instructions. Ours are a bit more detailed than the somewhat confusing package insert, but that comes from 10+ years representing the Dension line.
Reach out if no luck with your reseller or Dension's online support.
#74
Yeah, it is mildly annoying, but given that it is an aftermarket accessory for a relatively low production, highly "closed source" German car, it's not that surprising.
If I had it to do over again, I would have either not gone with the Denison or researched replacing the PCM unit itself, or soldering in an AUX jack.
I wish Denison would just give me their source code so I could fix the damn bug myself in an afternoon...
#75
I want to do this install and I do not have the CD changer option turned on, do I have to program PCM 2.1 to enable CD changer option or is is plug and play? Does the radio automatically enable and use the cd changer port Dension uses with having to program? If I have to try that option on does anyone know how?
