New Product: EVOMS 997TT "Leak Proof" Throttle Body Conversion Kit
Old 07-25-2016, 07:52 AM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
Originally Posted by GTRNICK
Shouldn't this problem be dealt with by IPD??? I mean they are the one supplying parts causing this issue?
Depends, in my case for example I have the 82mm TB, AMS y-pipe and use the IPD hose supplied with the 82mm plenum. So far using the factory skinny clamp its been holding however like I mentioned in an earlier post, its one of those things you keep wondering if its gonna pop off. Maybe its just an engineer thing, but a lot of times for us overkill = piece of mind
Again its not a big deal and can be dealt with a ton of different ways. Boost popping a connection off has been around since turbos started as you all know.
  #47
Old 07-25-2016, 07:55 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Fair point.
I guess you just need to find a descent jubilee clip
  #48
Old 07-25-2016, 12:12 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Fair point.
I got a bunch of these ( https://www.ecstuning.com/Porsche-20....6L/ES2730259/ )
Change them when opened dont over-tighten ... Using it on AMS y-pipe and oem coupler, holds 1.6 bar ......
  #49
Old 07-25-2016, 12:17 PM
M3 Maestro's Avatar
that's essentially what I am using, right now its just my stock clamp from the factory coupler. I could order some of these to have a fresh clamp on there, this group buy may be a while apparently.
  #50
Old 07-25-2016, 01:01 PM
GTRNICK's Avatar
I got a bunch of these ( https://www.ecstuning.com/Porsche-20....6L/ES2730259/ )f
That's it paint them black and put a logo on it and write some marketing jargon and put them up for $250 each
  #51
Old 07-25-2016, 06:07 PM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Meeting with our machinist tomorrow to finalize things and I will share with the class. If those who put their names on the list end up following through, I think we'll be able to cut a fantastic deal on these.
To recap the issue, I think there are two issues that contribute to so many problems with y-pipes blowing off with the 82mm throttle body kit:
  1. Most cars running the kit are running more boost with more air flow than those running the stock throttle body/plenum are
  2. The IPD plenum/GT3 TB combo put the throttle body much closer to the y-pipe than stock, meaning the coupler between them is very short and stiff. As the engine moves around, forces put into the y-pipe by the airbox and intercooler hoses cannot be absorbed by that coupler, and it puts stress on the connection causing it to fail occassionally
With a different coupler, you might be able to decouple the y-pipe and throttle body better and reduce that kind of failure, but the stock coupler is very long and flexible and those still blow off occasionally.
Our system is the nuclear solution, as it mechanically couples the two together WHILE allowing them to pivot and rotate relative to each other. With proper installation on compatible parts, the connection should never leak and cannot come apart unless the bolts are taken out.
Sam
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
  #52
Old 07-27-2016, 10:32 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Any news on the coupler Sam?
  #53
Old 08-09-2016, 04:05 PM
Bobbyfali's Avatar
SAM,
tomorrow was 15days ago my friend!
I am guessing we lost traction with this group by as some are waiting to hear what your answer will be.
What is happening?
Bobby Ali
ba
Sam
  #54
Old 08-09-2016, 07:00 PM
It is live : https://www.6speedonline.com/forums/...group-buy.html
Sam
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
  #55
Old 08-09-2016, 07:13 PM
I have sent a PM to all those who expressed interest informing them that the Group Buy is on. If everyone of those people follows through with a deposit, we are only two people shy of getting this going!!
Sam
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
  #56
Old 08-10-2016, 05:53 AM
LoanShark's Avatar
LoanShark is on a distinguished road
Hi everyone. is the group buy price still $500 ?
  #57
Old 08-10-2016, 10:07 AM
Bobbyfali's Avatar
Click link below for all info and yes it is $500+shipping!!:
  #58
Old 08-10-2016, 11:06 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
I need to buy a CNC machine and a powdercoating gun....
  #59
Old 08-10-2016, 12:18 PM
Originally Posted by arlrkerene
does this support the AMS Y-Pipe?
Fitment with the AMS Y-pipe has not been confirmed, as of right now I can only guaranty fitment on OEM and later build IPD y-pipes. I've reached out to AMS directly to try to put this to bed either way, I will let the group know what comes of it.
Sam
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
  #60
Old 08-12-2016, 09:42 AM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
If anybody wants one of these cheap, PM me, you can have mine for $100. I tried and tried to make it work and in the end, my shop had me go back to a traditional clamp. I've been running 22 psi for a year now with no problems.
Quick Reply: New Product: EVOMS 997TT "Leak Proof" Throttle Body Conversion Kit
