FVD Software tune (MyGenius Tool), Techart Exhaust tips…
No apologies necessary Austin. This is a community of Porsche enthusiasts and almost all of us come here for information (accurate information) and to share experiences. I passed along inaccurate information (received from a dealer) regarding a GIAC product and all you did was set the record straight. I, and I suspect all other 6Speeders, appreciate that.
False?
The FVD download takes 9-15 minutes and so does the upload - it is a total remapping, just like yours, and is customized based on the upload of the base file (more than a megabyte in sized). You must put the battery on a tender, regardless, as if the battery dies on upload you risk fragging the ECU as you point out. FVD has a recovery log file that helps with that issue in the hand held tool in NVRAM, which did not exist before, and is likely a concern with a Softronic PC based flash.
Your little code flasher do-hickey doesn't have much RAM at all, and is NOT a full reprogram - your "stock" file still resides on the ECU and the hand flasher (which never worked properly with my 997.2 BTW) just pulls the stock variables back into play, so it is NOT the same as the FVD system that re-uploads and re-maps the ECU with the base file . You validate my concern that there is NO way to HIDE a flash, due to the time stamp issue - though FVD claims to prevent a flash counter in EEPROM from counting, and therefore has the best chance to HIDE said flash (unlike you).
My point regarding reprogramming is irrefutable; if the DEALER wipes the flash, THEN you MUST go back to an authorized GIAC dealer AND PAY THEM to put it back in the car again - hassle, inconvenience, and from my experience, not the best in customer service. We don't have a great outfit like Champion Motorsport here in San Diego so I can't speak to your excellent relationship with them.
I was relating my truthful experience with FVD and the fact I could do the flash myself with instruction using something better than an FTP server on a Windows XP platform running Parallels on a MAC after the dealership eliminated my flash by uploading a new base file.
Austin, what part of my story was false?
Sure if this was the only way to do it, but it isn't, so why don't GIAC just fix this? And create the tools/cables/software needed, surely they should have the knowledge to do so?
Austin,
Our stance is, to give "untrained customers" as you call them, a very safe flash tool, ample instructional information and step by step support if necessary so that they have the freedom to program their cars themselves. After all lets face it, we are dealing with professionals from every walk of life who are knowledgeable in a great many things and programming a car with the right information is a simple task. As you know Austin, I am very respectful on these boards and also encourage competition. But, please don't infer that because customers are flashing the cars themselves they will not be making the power "that we do" as you say. Our files offer plenty of power and it is power that can be repeated over and over again consistently.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Rhonda Roxburgh
+1-954-571-2050 x 1
Reading all this makes me think again and wait for the COBB tune (.2 version) you just put the OBDII box on place and put what ever map including stock one, no need to call or go anywhere to do it, even if the dealer mess with your tune.
Also I will like to know whp & tq with the FVD tune, I believe is a good point when you are deciding which tune is better for your car.
While power is certainly an aspect to consider when deciding on a tune, Webcarconnection I would add that more important than sheer power is the experience, reputation and reliability of the company you choose. Very few companies can rival FVD Brombacher's 31 years experience with Porsche racing/street cars (BTW, Dunkleblau S is absolutely correct, the read/write process takes <15mins and is so easy I do it in my garage).
Thanks Chris, I'll give them a call. AWE Tuning in PA apparently also have a dyno. I need to confirm whether both dyno Turbos (i.e., if they have blowers/fans for the intakes).
http://powerhaus-performance.com/services/
If you go hit up member swc on here.
I wasn't sure if you were north or south Jersey
Powerhaus performance in Cherry Hill also has an AWD dyno
I can't tell if you're being serious or not
joseph_number1
07-19-2018 05:45 PM
