Evolution Motorsports EVT 1500
#46
Mid October for the Shift S3ctor half-mile in Coalinga, Ca. I drove to EVOMS and checked the shop out and they only had 1 big build there (the new shop car mayhem 2). John said he isn't taking any other big builds other than mine until after shift s3ctor.
#47
Thanks Tom! Yeah as you know I called every major builder in the world for build sheets and pricing. Just felt EVOMS was the perfect fit for me. I appreciate all your time you have taken to speak with me about builds. You and your company are a class act. You have the fastest VTG cars by far and great service as well. Like I've said before, give me a call when you come to Vegas!
hmm...I may have to plan a Cali trip around that time. I had a lot of fun at the last event in March!
#48
That would be awesome if you could. The last one you went to is No Fly Zone. Shift S3ctor is a lot bigger. You actually sit at the finish line as well.
#51
The 6466 turbos spool faster than the 3794's by a good margin. They also produce a ton of power. ETS made 1571whp with there 4.1 Gtr with them at 41psi. These turbos are good for 925hp each.
#53
Ha ha, there should be some real powa!
Btw 6466 spools a little bit sooner than 3794, about 200 rpm but there is no boost drop at 35+ psi. Very bad that there is no gen2 for this turbos
#54
I've seen a couple graphs with overlays with 6466 vs 3794's . Looks like they spool 500 rpms faster. We'll know soon enough. Hoping to run 40psi+
#55
6466 is a much nicer turbo with newer technology wheel. it also has a larger back which relieves alot of backpressure ( common on 996/7 TT applications even with larger turbos). as far as i know that turbo will flow more air with faster spool than a 37. I use the Gen2 cea 6466 Precision turbos which came out earlier and became very popular. Now FP made their own version of the 6466.
#TeamAIM
#TeamAIM
#56
#58
Anthony, I haven't been on this site for about a week, my son was married in Portland on Saturday. It's great to hear your next steps!
I believe I won't do anything additional for awhile, I enjoy driving it daily and if I do an engine build I wouldn't be able to have a reliable daily driver.
I'll be in Vegas this month and will contact you and see you at L'Atelier or elsewhere! See you soon.
#60
