Code 1233 and Fuel Pump Driver Module
Old 01-15-2017, 04:54 AM
Pigdog's Avatar
Pigdog is an unknown quantity at this point
Old 01-15-2017, 05:16 AM
Pigdog's Avatar
Looks to me the pump itself is probably a Ford that is inside a special housing made for the DB9 tank. Wish I could get that number off the pump itself. When I replace them I will get the number off the old unit and post
Old 01-15-2017, 07:26 AM
Pigdog's Avatar
Would anyone know the proper fuel filter for a 2005 DB9. I see 4 listed from 22 dollars to 121 dollars?
Old 01-15-2017, 08:10 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
Hopefully the attached includes your DB9 - it lists parts from 2005 and up.
File Type: pdf
Old 01-15-2017, 12:34 PM
Pigdog's Avatar
Thank You
Old 01-15-2017, 02:45 PM
Pigdog's Avatar
Anyone know the shop time on a fuel pump swap om a 2005 volante?
Old 01-16-2017, 02:19 PM
Pigdog's Avatar
The plot thickens (significantly) tested the pumps with a 12v source and both run?!?
Old 01-16-2017, 04:13 PM
Pigdog's Avatar
BINGO!
Threw code P0191 which is fuel rail pressure issue.
Monitored pressure and got 40 on right and 75 on left!!! No way that pump is putting out 75 psi
Datastream says fuel system 2 shutdown probably due to pressure out of limit
Tomorrow I swap the fuel pressure monitors to to see if the problem follows the monitor. Hopefully this is it.
Thanks!
Old 01-17-2017, 11:51 AM
Pigdog's Avatar
Alas the sensors were not the problem. while one sensor reads varying fuel pressure with rpm changes the other stays fixed at 75 lbs.
I am not sure where to turn now..... PCM?
Old 01-17-2017, 12:45 PM
Pigdog's Avatar
I taking the reading with the engine running. The PCM is not even seeing the 2nd pressure sensor. I unplugged it to see what happened and nothing. OB2 still said 75 lbs. I unplugged the other and got a fuel system error.
The reader also says fuel system 2 shut down.
I did the swap as you indicated and no change. The problem remained on the same side. I cleaned the plug and socket with deoxit to no avail
I am running out of options I think I will check the contacts with the ohm meter to see the differences in the plugs for the pressure sensors.
Old 01-17-2017, 01:32 PM
Pigdog's Avatar
Oh oh now I am getting P2105 which points to a PCM problem. This could explain all the mysteries.
Any one know if I can do a simple swap of these to check?
Looks like it may have to go to the dealer for diagnostics
Old 01-17-2017, 02:21 PM
Pigdog's Avatar
I will but I think it is ok.
The PCM is telling my OBD reader there is 75 psi of fuel pressure on one side. It does not matter if the pressure sensor is unplugged or not. I wonder if there is a bad sensor or other problem the sensor fails to the high limit.
Reading further P2105 and 2106 are common codes that indicate the car is in limp mode. The manual says to clear all other codes before worrying about these. I also pulled a p0193 which is fuel pressure too high.
The pressure sensors have 5v running to them from the harness as required so the PCM is apparently doing its job of trying to communicate with the pressure sensors. I just am starting to think there is an issue with this PCM.
Sure is perplexing
Old 01-17-2017, 02:57 PM
Pigdog's Avatar
I tested for 5V I used pin 2 for a ground is that good enough, In addition both pin 1 and 3 had 5V on both pressure modules.
Old 01-17-2017, 04:54 PM
Pigdog's Avatar
Here are the resistance readings
Rear pressure sensor (operating rail)
Pin connection Resistance
1 to ground 26
3 to ground 22
1 to 3 4.7
Front pressure sensor (non-operating rail)
1 to ground 5.2
3 to ground 0.5
1 to 3 4.7
My meter is not the best in the world but there is a significant difference in the impedance.
Thanks alot for your help btw......
Old 01-17-2017, 05:04 PM
Pigdog's Avatar
These resistance numbers were with the ignition off
