Instructions on swapping to Cayman spoiler
Old 10-30-2010, 09:24 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
For anyone interested, here is the instruction to swap the Boxster spoiler assembly for the Cayman one. Ideally, the bumper should be replaced with the Cayman unit for a more complete look, though it's not necessary. Enjoy!
This is direction to swap your 987.1 Boxster spoiler to 987.1 Cayman spoiler. The swap is relatively straight forward. It took me about 30 minutes (with pictures) and can be easily done with a small drill bit, a torx bit and 13mm socket.
Parts needed:
• Cayman spoiler (lower): 987 504 623 00
• Cayman spoiler (upper): 987 504 619 00
• Oval HD screw (Qty: 7): 999 919 233 07
Once the original spoiler is raised/extend, you’ll find 3 plastic, expanding rivets on the front side of the spoiler. Take a small pointy tool, a 5/16 should do the trick, to push in and through the center pin of the plastic rivet (don’t worry about the center pin, you’ll find & collect them later). Now, use your finger nail to “pop” the rivet off the spoiler
Here is what the picture of the plastic rivets pulled part, and the bag of oval HD screws.
Once the plastic rivets are out, slowly pull up on the front side of the painted spoiler cover to expose the 13mm nut holding the spoiler base to the metal posts. This is also when you can recover the plastic pin from the plastic rivets (circled).
Now, assemble the Cayman spoiler base on the post. You’ll notice the base can wiggle/move around a bit. This is normal. Don’t tighten the 13mm nut too much as you’ll want to align the base before tightening the nuts.
Next, lower the spoiler, close the trunk lid and align the spoiler base with the trunk lid. Once everything looks right, tighten down the nuts.
Take the 7 screws and tighten the upper spoiler to lower part. I used a towel in case I accidentally drop the screw into the bumper. And when it’s all done, it looks like this:
Old 10-31-2010, 07:59 AM
harryrcb's Avatar
harryrcb will become famous soon enough
Looks really sharp, thank for sharing. NICE
Old 10-31-2010, 09:19 AM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
lithium1330
AWSOME Article ! thanks for taking all the time to post this ,it should serve the boxster community well ..Grear job
also ...YOU CAR LOOKS SMOKING HOT!!!!!!!!!!!!!!! love the look of the Cayman spoiler on the boxster
Old 10-31-2010, 12:30 PM
chaud's Avatar
chaud is on a distinguished road
whoa, I have that towel too I think, lol...
nice work!
Old 11-23-2010, 08:18 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
thanks to Chris...
Just did mine... only painted the upper portion, since i have white/black theme anyways
Old 02-10-2011, 10:02 AM
eVoMotion's Avatar
eVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant future
Nice write up.
Nice white and black.
Old 03-28-2012, 09:03 PM
PaulR's Avatar
PaulR is on a distinguished road
Hello,
See you did the cayman spoiler mod... Looks fantastic, nice job and great instructions.
Wondering where you bought your parts and how much did they cost.... Going to do this mod and just looking for the best price / place to buy.
My local dealership tends to be very pricy!
Cheers,
Paul
Old 03-29-2012, 04:33 PM
Originally Posted by PaulR
Hello,
Cheers,
Paul
There are a Cayman owners upgrading to aftermarket spoilers. So, your best bet is to find someone selling their spoiler or convince they to sell it to you. Chances are, you'll need to buy the black plastic piece from dealer or a shop - unless the person is selling both upper & lower pieces.
Otherwise, I published the part numbers above. Dealer is one option, or Pelican parts if you want to buy new (less expensive than dealer). You'll need to paint the parts if you buy new. Another option is to find used parts through salvage yards. G'luck.
Old 04-01-2012, 03:03 PM
Fluid987's Avatar
Looks great !!!
Rguy
04-12-2020 11:11 PM
the5
10-14-2015 06:46 AM
arhim22
09-07-2015 08:49 PM
AM v12v
09-07-2015 02:17 PM
Quick Reply: Instructions on swapping to Cayman spoiler
