721 code
721 code
today on the way home my 04 CTT acted up again. PRND all light up and no gears selected but the car shifted and down OK. I used Durametric to pull a code and it indicated
"721
Input shaft speed inductive pickup-implausible signal, test conditions are not completed, fault is not currently active and causing a DTC light"
Any ideas of what is going on? I searched this forum, rennlist forum, and rentech forum but no information regarding 721 code. I saw a threat mentioned PRND light up with 1314 code only.
Any help will be greatly appreciated.
ALX5
"721
ALX5
I would take it right back to the Indy shop that you mention in your other thread about transmission issues.. If he replaced the input speed sensor... "input shaft speed inductive pickup" in the trouble code.. that sounds like the exact same part to me..
PelicanParts.com
997 Vendor Classifieds
10-05-2015 01:07 PM
