Bilstein b6 damptronic and pasm default 000c
Old Sep 28, 2015 | 11:07 PM
nagual911's Avatar
nagual911 is infamous around these parts
Question Bilstein b6 damptronic and pasm default 000c
Hi all
I ve récently installed b6 damptronic on my 97 TT mk1
First 20 km everything is fine.
But then PASM light came
Checking with a piwis it says front left default on electrovann code 000c
We tried to delete it but come back immediately
We tried to plug thé old one to see if the default disapear but no, even after deleting it with piwis
What is really strange is that when i unplug totally the coil no more errors
Sport button works fine as Well for the damper one.
With the piwis we tried to see if the pasm unit was damaged but we fan access it easily...
Car was working fine before the change.
Any idea of what it can be?
Thank you
Old Sep 29, 2015 | 07:02 AM
IMI A's Avatar
IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !
Wink
Most likely one of the dampers is faulty or a loose connection. Disappointing if it is a faulty damper but I suppose these things can happen.
Old Sep 29, 2015 | 09:08 AM
nagual911's Avatar
We have checked all the dampers.
We switch the faulty dampers by an original one same problem.
Asking to a porsche tech he says that they have ton reprogramm the PASM module
Old Sep 29, 2015 | 09:15 AM
IMI A's Avatar
Bad luck. Probably just as cheap to buy the TPC PASM module. Didn't realise you had to reprogramme the module. What a pain.
Old Sep 29, 2015 | 09:23 AM
nagual911's Avatar
that 's my fear...
As he says if it does not work we'll have to change the module...
Old Oct 1, 2015 | 01:52 AM
nagual911's Avatar
Any other idea ?
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
BM991
Jan 20, 2016 01:24 PM
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
MONKY LONDON
Sep 28, 2015 07:16 AM
