Code P2181 Cooling system performance Implausible signal
Hello,
I have driving my Cayenne in a while and today when I took it out, the engine light turn on. I used my durametric to scan for the code and it come up with "2181 -Cooling system performance - Implausible signal"
I checked the coolant and its not empty but nearly full. Should I check somewhere else for the issue?
Thanks,
Thanks,
Normally means thermostat failure. The ECU expects the engine to reach a certain temperature after a certain time, if it doesn't it may throw this code. Have a look at your temp gauge and check if the engine is taking longer to reach normal operating temp.
I have just changed mine recently.
04-28-2022 12:38 AM
