You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Here are a few photos of a 997 TT's exhaust, before and after. (Don't mean to thread jack, hoping this will add to the thread.)
Process was:
Soak with Prima Mystique
Rub off most of grime with microfiber
Polish with P21S multi surface restorer (amazing product, works really well on a wide variety of applications)
McD what did you use on the inside of the pipes.They look great.I know they are painted black so do you leave them alone or clean them and blacken them with something?Thanks
Just used the Mystique (auto wash) and let it sit for a few seconds, then rinsed and wiped it out with a microfiber. Nothing to dress the inside, just left it plain. The pics show some smudging on the plastic bits just outside the pipes which was cleaned up after those pictures were taken.
tell me-
how does the zymol metall compare to the einszett metallic polish&wax? thanks!
Zymol Metall is not a wax, it's a true metal polish. 1z mpw is a polish/wax that's designed for the paint, not metals. Zymol Metall comes in a towlette form and the 1z mpw is a liquid paste that is applied with a microfiber pad applicator. Both have their own unique function.
__________________ 6speed Members use Promo Code 6speed to receive 10% off entire order
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
One more question-
I tried this exact same technique today for over an hour with the same products. My car is an E55 w 55k miles, and the inside exhaust tips have never once been cleaned.
My result is definately better than it was originally, and I know you're doing this to a newer 63 car, but mine is nowhere near this level of cleanliness or perfection.
Should I invest more time and energy with this process, could you recommend anything else, or am i stuck being at about 50% perfect??
Thank you so much!
One more question-
Thank you so much!
What exactly did you do and use? There have been some pretty bad tail pipes that have been brought back to life using the same procedure and products. Sometimes, you may have to do it a few times. But, there are times where the damage is too far gone and that's the best that can be done. Can you take some pictures and post? Thanks.
I followed your directions to a T, the exact same way, including using the same products. Give me your email so I can send you photos of the end result. Thanks!
