WEVO mount my engine
Old 03-02-2010, 01:09 AM
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
Originally Posted by cgng30
my mistake, i should have paid attention with the lime colour car u have, its a gt3 rs. i have a 997 tt and i am leaning towards the wevo instead of the rs mounts, it seems like wevo is designed to fit. havent decided yet, not sure how much more vibration/niose from rs mounts verses wevo...
Vibration is not noticeable at all with WEVO engine mount unless you are in your driver seat without pants
Originally Posted by justatoy
WOW....just in time......MY Wevo's showed up today for my 997 S.
Sounds like you are happy with them!
Thanks for the write-up on the install.....
Stacy
Cool, let us know how you like it
Old 06-25-2011, 10:20 AM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
Rep points for Mikymu for the detailed writeup on the Wevo mounts. I swapped out my stock mounts in an hour using your writeup as a guide. Many thanks.
And the results are outstanding. The 'feel' of greater stiffness and being connected to the car. A bit more vibration at idle and up to 1500 RPM. Perhaps a bit more vibration throughout the band, but to me it all feels much more like a sports car should feel.
So, no good deed goes unpunished. Can anyone point me to a post of a transmission mount swap. I bought a new one from SunCoast acknowledging that these rubber mounting points give out over time and with my car being a 2005, I'm a likely candidate for the swap. It's for a 997S rather than a GT3 (my next ride I hope) if that makes a difference.
Again, many thanks.
V.
Old 06-25-2011, 03:12 PM
Vader996GT3's Avatar
Vader996GT3 is on a distinguished road
I'm with mdrums. I wish you were my neighbor too! Awesome write up. Those WEVO mounts look awesome. I've been congtemplating this upgrade for my 996 GT3.
Old 11-06-2011, 06:59 PM
Roadie's Avatar
Roadie will become famous soon enoughRoadie will become famous soon enough
I love my Wevo semi-solid mounts!
They make my car feel more planted and solid. Very nice upgrade. I know I'll love them even more when I get to the track.
Old 02-01-2014, 03:34 PM
.db.'s Avatar
.db. is on a distinguished road
Thanks for this awesome thread! It seems I might have hit a snag in installing my WEVOs. When I look at the bottom bolt, it's a star-shaped thing. Is this the mount bolt? Can I use these WEVOs on a 997.2 S PDK?Attachment 328204
Attachment 328206
ID:	328207   Click image for larger version
Old 02-01-2014, 07:30 PM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Check out this DIY for the Wevos.
https://www.6speedonline.com/forums/...ml#post2744059
Old 02-02-2014, 12:27 PM
.db.'s Avatar
Thanks for that additional info.
997.2 from below. any ideas on where to place the jack to lift the motor for changing the mounts?
Old 02-02-2014, 12:57 PM
alpine-al's Avatar
Jack up the rear of the car from the regular jack points in front of each rear tire. Position your jack stands as indicated below (at red marks). To take the weight off of the engine mounts, put a short piece of 2x8 lumber flat under the oil pan and carefully jack it up a bit.
Old 02-02-2014, 04:00 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Anyone done a 996TT or GT2 without removing the bumper and IC hoses? Seems like it can be done by undoing the hoses at the Y-pipe and bending out of the way...?
Old 02-23-2014, 11:01 AM
.db.'s Avatar
Thumbs up
Worked great. Thanks!
Agree with previous posts, great upgrade. The car is significantly more responsive and more fun. A blast first times out at COTA and H2R, can't wait to try on a track I've been to for comparison.
Old 03-22-2014, 07:08 PM
ASLAN's Avatar
Did my install (RSS mounts) a couple months ago. I did notice some slight vibration initially, but I must have gotten used to it, because I no longer notice anything! I did have one concern though. Tightening the M12 nut to just 60 ft/lbs seems low...? In another thread they mention 75 ft/lbs. When loosening it for the R&R, it sure felt like a whole lot more from the factory. Any comments?
Old 05-10-2014, 12:51 PM
rix's Avatar
rix
rix is offline
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
I thought the same thing, and put mine at 70 ft lbs. Felt a little better.
04-28-2022 12:38 AM
nlakind
11-06-2015 10:15 AM
henryr
09-24-2015 08:22 PM
pwdrhound
08-23-2015 07:36 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: WEVO mount my engine
