Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Dash light on my Mini
Old 10-03-2006, 11:59 PM
allanlambo's Avatar
allanlambo has a little shameless behaviour in the past
I cant find the owners manual on my mini, and I have a yellow light flashing. It is in the center speedometer, second light from the far right. It is yellow and has an exclamation point on it? DO you guys have any ideas?
Old 10-04-2006, 12:22 AM
SKXF430's Avatar
SKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud of
Is it an exclamation point with a triangle around it? If so, it could be your DSC light. However, when I switch my DSC off, it stays a constant yellow.
Old 10-04-2006, 12:35 AM
Mike S's Avatar
Mike S will become famous soon enoughMike S will become famous soon enough
It's the tire pressure sensor light. Should check the pressure of your tires, and if that all good to reset the sensor is easy.
The car must be off, turn the key until all the lights are on. Then look for a button near the handbrake that has the same symbol as tire pressure sensor as the one you see on your dash. Hold the button down until that specific yellow light goes off. Turn the car off again and then start the car. Drive a couple miles and the light should go away.
Old 10-04-2006, 01:45 AM
allanlambo's Avatar
Cool! I will try this tommorow. Thats what I was thinking it was, as it sort of looked like a tire.
Old 10-04-2006, 03:50 AM
Mike S's Avatar
No worries let me know if you come across any more problems.
PelicanParts.com
09-01-2015 02:36 PM
GSR Autosport
08-26-2015 05:20 PM
ECS Tuning - BMW
08-21-2015 02:00 PM
ECS Tuning - BMW
08-21-2015 01:47 PM
PelicanParts.com
08-20-2015 04:01 PM
Quick Reply: Dash light on my Mini
