Notices
FS MA USA 2002 Subaru WRX STI RASpec Impreza time attack / road race car
Old 08-23-2015, 10:36 AM
eclip5e's Avatar
eclip5e is infamous around these parts
FS MA USA 2002 Subaru car
Year: 2002
Make: subaru
Price: $35000
Mileage: 1
Color: White
Location (State): MA
Transmission: Manual
Drivetrain: 4WD & AWD
sold!
Old 11-22-2015, 03:56 PM
eclip5e's Avatar
sold!
Old 03-23-2017, 10:02 PM
ciaka's Avatar
Somewhere on here or another porsche site I have a diy with pics on control arms replacement
Old 05-01-2018, 05:02 AM
ciaka's Avatar
To put some finishing touches on this thread, there are few things that can make sounds describrd. Each has to be looked at, or uf u do full bore approach, do all at once to fix sounds issue.
1. Lower control arms - known culprit, squeak or thud when going over bumps. You can inspect and see bushings tears. Fix is to replace control arms.
2. Upper control arms - known culprit, squeaks over bumps. Will be hard to inspect bushings as they are obstructed. There is process to inspect on cayenne section. If you replaced lower control arms, and sounds still present, replace the upper control arms. Plus read next point.
3. Upper shock mount bushings - known culprit in air suspension, clunking sound over bumps, especially low speed. These are rubber stops inside each shock. They are supposed to keep internals aligned, but if they get worn, internals of shock stary flopping around, hence clunking sound. Remedy is to replace said bushings. I have a diy from cayenne section on how to do this. Not hard, and if youre doingupper control arms, you have to remove air shocks, giving you perfect opportunity to to replace.
4. Sway bar bushings - not as common for squeaks. Easy to replace, but i would do thease aftervabove 3 are addressed. I have diy on sway bar bushing repair on here in cayenne section, i think.
5. Sway bar links - not as common for squeaks, easy to replace. If i reolace sway bar bushings, might as well do th ese too, cheap and need removal to change sway bushings.
After fixing my cayenne which has similar noises, thst users ovserve and repair, i would tackle these noises in shown order. Very doable as diy.
Old 02-12-2019, 09:24 AM
Itzkirb's Avatar
Old 03-21-2019, 11:04 PM
PorschenaroundCT's Avatar
PorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud ofPorschenaroundCT has much to be proud of
Excellent congrats 👏
Old 07-29-2019, 11:13 AM
Itzkirb's Avatar
Old 04-02-2021, 02:01 PM
GraceLambert89b7o's Avatar
GraceLambert89b7o is infamous around these parts
Smile
Old 04-28-2022, 12:38 AM
behbodsanat's Avatar
behbodsanat is infamous around these parts
Epoxy parking lot is one of the types of epoxy flooring that can be easily applied on concrete surfaces. Epoxy parking lot flooring is seamless and integrated. The unique feature of this industrial flooring is its extraordinary adhesion to concrete, stone and ceramic surfaces. It should be noted that to perform epoxy parking flooring on ceramic surfaces, special requirements must be observed, resistance to chemicals, detergents, fire, fungi and bacteria are other features of this type of epoxy flooring. Epoxy parking floor maintenance is easy and cheap. The variety of designs and colors of epoxy parking floor is relatively large and different, and it is even possible to design a line on these floors. The durability of epoxy parking flooring is very high. Therefore, they are used for the floors of parking lots of industrial and commercial complexes that have a lot of traffic.
993man
03-23-2018 01:41 PM
xkdrbtx
Merchandise For Sale / Wanted
08-18-2017 05:11 PM
henryr
06-08-2017 06:14 PM
superlubricity
02-21-2017 11:39 AM
Quick Reply: FS MA USA 2002 Subaru WRX STI RASpec Impreza time attack / road race car
