DIY 997 Series Porsche 911s
#62
#64
Today I completed a 3-weekend project on my 2007 C2.
- Alan
- New X51 Headers
- New NHP 200-Cell Cats
- New NHP Sport Mufflers
- New Dual Chrome Tips
- New Denso IK22 Spark Plugs (note: gap had to be adjusted from 0.8 to 1.6mm)
- New Beru Ignition Coils (hadn't planned on doing these; lesson learned)
- New IPD 82mm Comp Plenum
- New GT3 Throttle Body
- New BMC Air Filter
- New Serpentine Belt
- Softronic ECU Flash
- Sore muscles, a few bumps on my head, and a bruised thumb
- Alan
#65
I know this is an old post but my question is the drain plug, it looks like a #8 allen plug on bottom of pan. I don t know what you are saying about it being on the bottom of the sump? Please explain.
#66
Thats it.
#70
Boys did i miss something.. where is the Oil Change DIY ? Or is that too easy that it wasnt necessary to write up ?
I would like to do mine so if anyone has a link it would be appreciated..
Howard
Howard
#71
different slightly between 997.1 and 997.2. there is the 997.1 posted already. I ll do the .2 in a few weeks.
https://www.6speedonline.com/forums/...ml#post2935790 heres the .1
#72
Thanks Mark. Its my first time so i'm a little anxious. Is there anything I should see or do differently on the .2 that is different than on the .1 ?
Thanks again in advance.
Howard
Howard
#73
Yes, your oil filter will be gotten from the top under the hood instead of under the car.It s the big black cap on the right side of engine (36MM). Look at the filter when you buy the new one and you ll will see it comes with a rubber ring to also be replaced on the cap. I think once you do it once this top filter is easier. With the right drain pans the car can stay on the ground. If I remember, the drain plug is a #8 allen. Do the oil filter cap first in case you can t get it off,,, before you drain the oil and then realize that.
#74
#75
Hello I am in NYC and I need to take my car in for some work, I have not had the best experience with Manhattan Porsche - does anyone in the area have any other recommendations? Thank you very much!
